Rollback of Firmware SG4K100174
TX2323
Message 2 of 2
Where can I download earlier firmwares as since firmware SG4K100174 was installed without any advice resulting in third party mesh systems no longer connecting to the router. Also unable to turn off wifi without it affecting the LAN ports.
Would also like to know how I can stop future firmware being installed as our home network was working fine using SG4K100158 now has to be restarted every few hours as devices disconnect or are blocked
1 REPLY 1
Message 1 of 2
Hi TX2323
Unfortunately we unable to roll back firmware to older versions.
Which mesh system are you using?
Anonymous User
