WiFi dropping out
LRJFORD
Message 10 of 10
    My WiFi keeps dropping out while on a laptop, phone or tablet and it's doing my t!t$ in.
I'm using a LAN connection to contact you.
Fault finding says, that my Sagemcom Fast 5364 is working ok, and is using the correct firmware.
Any help would be appreciated.
Thanks in advance
AL REET
9 REPLIES 9
Message 1 of 10
Thanks for confirming and please let us know how you get on.
Message 2 of 10
Hi Keith,
               Spent over an hour with the talktalk tech team for them to confirm that my router was faulty.
TalkTalk sending out a new one. Fortunately, I still had an old talktalk router and I'm using that one just now.
Thanks for ur help
                                 lrjf
AL REET
Message 3 of 10
Hi LRJFORD,
How are you getting on, have you been able to access the router UI since your last post?
Message 4 of 10
Hi @LRJFORD
Just to confirm, is the problem that you cannot access the router's login screen, or is the password not recognised? If you can access the login page, what firmware does it actually show at that point? If the password is not recognised, try it in the morning, as I found out with mine, it suddenly let me in and I have no idea why. That is of course if you have V174.
Message 5 of 10
Hi Keith,
Can't access it in incognito mode .
AL REET
Message 6 of 10
Hi @LRJFORD
Not being able to access the router's UI is normally because the firmware has recently been updated to V1.74. This is a known problem & usually lasts for a day or so, in the meantime if you use your browser's incognito mode, that will get you in. If you want help to check WiFi interference, then please let me know.
Message 7 of 10
Hi, I can't access the router using 192.168.1.1. either
AL REET
Message 8 of 10
Hi @LRJFORD
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Divsec
Message 9 of 10
Hi @LRJFORD your post has been escalated and you should hear Monday. In the meantime please add your landline phone number to your community profile so that your account can be identified by the team here https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personalinfo
Also have you tried using only 2.4ghz or 5ghz for a while to check if this is frequency specific?
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
