Router randomly cutting off internet
Pabroon46
Message 8 of 8
I have been having problems with my talktalk router disconnecting from the internet. Wi-Fi is still showing, but each time, I have to reboot the router, and it reconnects. It seems to occur randomly. I have had all the chat/bot conversations and line tests say all is working - which it is, until it’s not. It is a very irritating problem. In desperation, I have started using another router hub from Nowtv, and there is no problem with that one. After many long conversations with Talktalk about whether my router needs replacing or updated, I was promised a call back to discuss things. That was a week ago, but I’ve heard nothing.
7 REPLIES 7
Message 1 of 8
Thanks for letting us know.
Message 2 of 8
The new router is installed and everything is much better.  I have returned the old equipment. Thank you.
Message 3 of 8
Hi @Pabroon46
I've ordered replacement router, there will be no charge for this.
Please allow 24-48hrs for this to arrive. Let us know how the connection compares with this router.
Message 4 of 8
I think I have replied to this, but if not, then yes please. I assume there will be no charge, as my router is not working properly
Message 5 of 8
Hi @Pabroon46
Would you like me to send a replacement router?
Message 6 of 8
Hi @Pabroon46
I think we should replace the router, are you happy for me to arrange this for you?
Divsec
Message 7 of 8
Hi @Pabroon46 good to know you are back up and running and effectively diagnosed the issue. The team will be back on Monday and will get this sorted for you.
