on 13-07-2025 12:47 PM
Hello, just wondered if I could get a replacement for my router seeing as the white light is no longer showing up.
on 18-07-2025 11:56 AM
No, that's everything, thanks.
on 18-07-2025 11:41 AM
Mark, I have just placed the order on your account of the returns bag. 🙂 as explained earlier that I have also attached care notes and provided the delivery timescale.
While I still have you on the platform, would there be anything else you would like for me to further assist you with apart from what we have discussed today?
on 18-07-2025 09:41 AM
Perfect! I just wanted to make sure that your connection is fine which is one of the most important things. 🙂 I have shared over a private message to the matter as I will need to confirm minor detail on your account.
on 18-07-2025 09:33 AM
Pardon? My connection is working, fine.
on 18-07-2025 08:07 AM
@MarkHarrison, have you tried checking the status of your connection on MyConnection via MyAccount? 🤷
on 17-07-2025 05:43 PM
Okay, that should be`easy we can send you a returns bag. I will need you to confirm some details on your private message section.
Kanya
on 17-07-2025 05:41 PM
I received a letter along side my new router saying that I may be charged £50 if I don't return my old equipment so if it is necessary to return my old router then yes, I would like a return bag, thank you.
on 17-07-2025 05:38 PM
on 17-07-2025 05:28 PM
Back again 😂 Forgot to ask if I will be charged for this router or for not returning my old, broken router? Cheers.
on 15-07-2025 02:36 PM
Thank you for chatting in, should you require further assistance please do not hesitate to get back to us :).
Have a good day!😊
on 15-07-2025 02:18 PM
No, that is everything, thanks. I appreciate all the help.
on 15-07-2025 12:28 PM
Hi there @MarkHarrison, I escalated this for you and got the feedback. I have ordered a new router for you since the one you have is faulty. The new router will be delivered in the next 2 - 3 working days, thanks.
While I still have you on the platform, would there be anything else you would like for me to further assist you with apart from what we have discussed?
on 14-07-2025 11:35 AM
Appreciate all the help, mate. You'll have to excuse my lack of technical skills.
on 14-07-2025 11:32 AM
OK, thanks for that, we got there in the end. I have asked one of TalkTalk's support team to pick up your thread and replace it for you.
They aim to respond within 48 hours (Monday - Friday), excluding Bank Holidays, but if more urgent, you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first.
on 14-07-2025 11:30 AM
But the light is still not working on my router, btw.
Thanks, the indicator switch is on.
on 14-07-2025 11:24 AM
OK, that one is different. Log in to it & go to:-
Dashboard > See Internet Settings > Manage advanced settings > Advanced Configuration > Maintenance Diagnostics > Indicator Status Management
on 14-07-2025 11:12 AM
Huawei DG8041W
on 14-07-2025 10:21 AM
Exactly which router do you have?
There are four Wi-Fi Hubs and they can be different:-
on 14-07-2025 10:07 AM
I have now managed to login but after clicking on Manage advanced settings, there is no TalkTalk Wi-Fi Hub > Device info > Light control. Now I did click on hardware check and the status came back as normal so I guess it's okay, I'll just have to deal with there being no white light on, I suppose.
