on 18-02-2023 07:33 PM
Good evening.
As some other users have experienced with the new firmware SG4K100158 I have lost access to some connections to particular automotive equipment update servers and the most oblivious problem is that Sky on demand services are un-reachable. These problems are completely resolved by installing a Netgear router. I would be grateful if the issue could be investigated. I had this problem previously with a previous firmware update and debbie reinstalled a fixed firmware to resolve the problems.
smhsmh
on 28-03-2023 11:59 AM
Hi smhsmh
Our Devices Team have a new firmware version which will resolve the firewall issue.
Please can you connect the TT router and we can push the update to your router.
on 05-03-2023 10:59 AM
Hi Debbie.
Thanks for the update although I am not convinced that the medium setting is secure enough. If this was the case there would be no need for a high setting at all. The previous firmware worked on high without the issues experienced with the new firmware. Although I am not a firewall expert it does seem to be a configuration problem. As it seems that the talktalk router seems incapable of achieving a normal connection that other routers do without any problems I will use an alternative router.
regards
smhsmh
on 03-03-2023 06:05 AM
Hi smhsmh
I'm really sorry for the delay. Our Devices Team have advised that the medium setting for the firewall is fine and it should have been set to medium in the first instance. There was an issue with the firmware which set this to high and resulted in the VPN and other issues.
on 02-03-2023 04:40 PM
Hi Debbie
Is there any update on this? It is annoying to have to keep changing firewall settings as I am not prepared to keep it on medium. If there is no solution in sight then could you revert the router to the previous working version as you did last time I had this problem.
Many thanks
smhsmh
on 20-02-2023 10:14 AM
Hi smhsmh
That's great, thanks for confirming.
I have also fed this issue back to our Devices Team.
Thanks again.
on 20-02-2023 10:10 AM
Hi Debbis.
Have changed firewall as requested and this resolves the problems I am having.
Hope this helps to resolve the issue.
smhsmh
on 20-02-2023 07:01 AM
Hi smhsmh
Please can you try changing the firewall settings on the TT router to medium and then testing again?
on 19-02-2023 09:11 AM
Hi Divsec
Thank you for the update
smhsmh
on 19-02-2023 09:03 AM
Hi @smhsmh your post has been escalated and you should hear tomorrow.
