on 31-12-2023 06:27 PM
I have a DG8041W router running software version 1.05t.
We are losing connection several times a day. The maintenance user log shows the the system is being reset with the cause always being 'due to kernel panic'.
Other posts suggest that a software upgrade to version 1.06 often resolved the problem.
When you are up and running after New Year, could an upgrade be done please?
Thank you.
Answered! Go to Solution.
on 08-01-2024 06:42 AM
Hi Jonnylawman
I'm so glad to hear this 🙂
on 06-01-2024 06:51 AM
Debbie,
It does seem to have improved with no noticeable disconnections!
I will keep monitoring it, but thanks for your help.
on 05-01-2024 08:18 AM
Hi Jonnylawman
How's the connection been since the firmware update?
on 02-01-2024 08:32 AM
Hi Jonnylawman
Apologies for this.
I've made a change to your router firmware, please can you monitor the connection this week and I will check in again with you on Friday to see if everything is working ok.
on 31-12-2023 09:51 PM
Yes, that is the resolution. I have asked one of TalkTalk's support to pick your thread up and upgrade it for you.
