EchoLife DG8041W Home Gateway rebooting over and over again ( V1.05t)
spindalero
Message 15 of 15
Please help. router reboots multiple times throughout the day and evening
this error in log
[Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
can you update the firmware to see if it helps?
TIA
14 REPLIES 14
Message 1 of 15
Hi spindalero,
DLM did change your profile on the 4th but there wasn't much of a speed increase, hopefully it will continue to change your profile and you'll see faster speeds over the next few days
Message 2 of 15
correct. the new hub 2 does not reach the same areas of the house as hub 1 did. and it is positioned in the same location. still waiting for speeds to increase as well... thanks for your help.
Message 3 of 15
Hi spindalero
Do you mean the wireless coverage is poor with the new router?
Message 4 of 15
Hey Karl,
The connection has been solid. no reboots. speed is creeping up slowly. range within house is poorer than the original hub. will need to look at options for improving this as not acceptable at the moment.
thank you
Message 5 of 15
Hi @spindalero
How has the connection been over the weekend?
Message 6 of 15
Good morning,
Thanks for the update. We'll check back in with you in a few days to see how both the stability and speed compares as it can take DLM 48hrs to start optimising the connection.
Message 7 of 15
Yes, the new router arrived and installed last evening. It did lose connectivity overnight but we will see how it goes. speed is awful gone down from 35mb to 21mb. but expect that might creep back up.  might be time to shop around for full fibre with a decent router/mesh... thanks for your help though.
Message 8 of 15
Hi Matt  @spindalero
Message 9 of 15
Hi Matt  @spindalero
The router is on its way, please allow 24-48hrs for this to arrive. There will be no charge for this.
Message 10 of 15
Hi, provided there is no cost to me. Then please send a replacement router out asap. Thanks in advance...
Matt
Message 11 of 15
Hi @spindalero
We no longer provide firmware updates for this router. Would you like me to send you a new router? (different make and model)
Message 12 of 15
Sagemcom.
Looks similar. Will receive automatic updates, @spindalero.
spindalero
Message 13 of 15
its so painful at the moment! always has been tbh! but worse recently. what are they sending out these days?
Message 14 of 15
I don't think the update is available any more, hopefully the support team will offer a router swap out for a newer model when they come back online tomorrow.
