The speed from my router to devices has slowed again.
Taffy57
Message 63 of 63
The speed from my router to devices has slowed again, I am on fibre 65 package but only getting 10 to 15 mbps when i do a speed test. I raised a fault on the 19th March which was resolved (apparently)
I have had this replacement router for about 12 months which has worked fine until recently
Please help
Neil Acreman
62 REPLIES 62
Taffy57
Message 41 of 63
Cable is connected to the correct port as per when it was installed, nothing has changed my end, it has been working perfectly since it was installed until now
Message 42 of 63
Thank you. Can you please complete the following checks and answer the questions
Please ensure the TalkTalk router is securely connected to the data (computer) port of the master telephone socket, with no microfilters in use.
Checked and Setup was already correct?
Corrected setup?
Taffy57
Message 43 of 63
No Damage
Message 44 of 63
Thank you, Does any of the equipment appear to be damaged?
Taffy57
Message 45 of 63
Open Reach NTE 5C MK 4
Message 46 of 63
I need to find out what type of master, or main, telephone socket you have so I can give the correct troubleshooting advice.
The master socket will be a white box on a wall, and is where the telephone line connects into your house from outside.
Please browse to https://community.talktalk.co.uk/t5/Articles/Your-guide-to-main-phone-sockets/ta-p/2205432 - this page shows you images of the different socket types so you can identify which you have.
Can you confirm what type of master socket you have please?
Taffy57
Message 47 of 63
No it is continually switched on.
Message 48 of 63
I understand, Do you regularly turn your broadband router off? For example, do you switch your router off at night?
Taffy57
Message 49 of 63
I only use in the living room there is no requirement to use anywhere else
Message 50 of 63
Thank you. Does the problem occur everywhere you try and use the Wi-Fi, or just in certain parts of the house - for example upstairs, or outside the house?
Taffy57
Message 51 of 63
No
Taffy57
Message 52 of 63
OK thank you, last time i was sent a new router which resolved the issue (for 12months approx)
Message 53 of 63
Do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
Message 54 of 63
Thank you so much, I will carry out checks.
Taffy57
Message 55 of 63
I have rebooted the router and carried out two speed tests and both times iy was showing 15mbps, so it is no different
Message 56 of 63
There seems there was an outage, which has now been resolved please refresh your browser and let me know if you are still experiencing the issue.
Taffy57
Message 57 of 63
Yes i carried out a speed test this morning and it was showing 15 mbps.
Message 58 of 63
I understand it was then resolved however the issue has recently come back. Was this today?
Taffy57
Message 59 of 63
I noticed the issue on 19th March when I did a speed test, I then did a diagnostic test and raised a fault
Message 60 of 63
Perfect. Can you please confirm when did you start noticing the issue?
