Unable to access sites via hyperlink on my work laptop
Sjsainsbury591
Message 18 of 18
My work has been investigating this issue for weeks now and they have come to the conclusion that it’s likely to my router or Talktalk that is restricting access.  If I’m in the office hyperlinks work fine so it is a home issue.  I have checked kidsafe etc and they are all turned off.  What else can I try?
17 REPLIES 17
Billx
Insightful One
Message 1 of 18
Hi, @Sjsainsbury591
Those 4 Teredo rules have been added automatically via UPnP
You've obviously have not added any rules yourself.
And it seems you don't know why those Teredo rules have been placed there.
I don't fully understand Teredo myself and avoid it.
If it was on my computer, I would delete them.
So, the thing is that you have not added any rules yourself.
 As far as upgrading the router's firmware yourself (that @nomfezeko-TT referred to), that can't be done on these TalkTalk routers. Only TalkTalk can do that.
Bill
Message 2 of 18
this is all I could find attached
Message 3 of 18
Here’s a more detailed explanation of how to perform each step:
-Access Router Settings:
  1. Open a web browser on your laptop.
  2. Type your router's IP address into the address bar. Common IP addresses are 192.168.1.1 or 192.168.0.1. If you're unsure, you can check the back of your router or refer to the user manual.
Log in with your username and password. If you haven't changed these, they may still be the default (often "admin" for both username and password). Look for a section labeled "Firewall" or "Security." Check if there are any settings that might be blocking access to certain websites.
-Fez.
Message 4 of 18
Yes.
Message 5 of 18
is your broadband working fine at the moment?
-Fez.
Message 6 of 18
Thank you
Message 7 of 18
Thank you, please give me a moment as I look into this.
-Fez.
Message 8 of 18
Yes that’s correct
Message 9 of 18
Thank you, so this only happens on the laptop but operates perfectly fine with other devices?
-Fez.
Message 10 of 18
Yes but only on my work laptop.  This issue started about 2 months ago and before that I was able to access them.
nomfezeko-TT
Message 11 of 18
Thank you. Are you only having issues with hyperlinks?
-Fez
Message 12 of 18
Yes
Message 13 of 18
Are you currently home where the TalkTalk services are installed?
-Fez
Message 14 of 18
Thanks for all that info but how do I actually do all that.  I obviously know how to turn off the router and restart it but the rest I am clueless about.
nomfezeko-TT
Message 15 of 18
Thank you providing detailed information about the issue you're experiencing. I understand how frustrating it can be when you're unable to access certain hyperlinks at home, especially when everything works fine in the office.
Since your work has determined that the issue is likely related to your router or TalkTalk, here are a few additional steps you can try to troubleshoot the problem:
- Sometimes, firewall settings on your router can restrict access to certain websites. Log into your router's settings and check if there are any firewall rules that might be blocking access, also consider changing your DNS settings to a public DNS service like Google DNS (8.8.8.8 and 8.8.4.4) or Cloudflare DNS (1.1.1.1). This can sometimes resolve access issues.
- Ensure that your router's firmware is up to date. An outdated firmware version can lead to connectivity issues. You can usually find the option to update the firmware in your router's settings.
- If you haven't already, performing a factory reset on your router can sometimes resolve persistent issues. Just be sure to note down your settings, as you'll need to reconfigure your network afterward.
 If none of the above step's work, please do let us know so we can run diagnostics on your line and check for any restrictions or issues on our end.
-Fez.
Sjsainsbury591
Message 16 of 18
My firm uses a security Mimecast which checks all links before opening but at home it just gets blocked, they say by my internet provider.
nomfezeko-TT
Message 17 of 18
Hi there @Sjsainsbury591, thank you for reaching out to us, could you please kindly elaborate this for me so I can be able to support you further, we are willing to help.
-Fez.
