Upgrade Older TalkTalk Router
Markkk01
Message 10 of 10
Been with TalkTalk for a long time now (Over 6 years) and I am still using the same Router (Just renewed the Contact, so no New Router), I have to restart it at least 1 or 2 times a month, as it just stops.
Is it possible to get a newer Router to replace the one I have ?
9 REPLIES 9
Message 1 of 10
Markkk01
Message 2 of 10
Hi Chris, thanks for the reply. A bit pointless sending the older model out the same as the one I already have.
I was only seeing if there was an upgrade available anyway.
So, I will stick with the one I already have until the renewal comes up and go from there.
Mark
Message 3 of 10
OK thanks. I can send a replacement router but it will be the same make and model, would you like me to arrange this?
Markkk01
Message 4 of 10
Hi, it's a Sagecom CS 50001 - SG4K100206
TalkTalk WiFI Hub
Message 5 of 10
OK, which router do you have?
Markkk01
Message 6 of 10
Hi Chris, forgot to restart yesterday but will be restarting tonight, as it has been getting slower, so was going to get ahead of a complete stop..
Will be first retart this year.
Message 7 of 10
Thanks. When was the last time that you had to restart the router as I can't see any recent reconnections?
Markkk01
Message 8 of 10
Hi Chris, sorry I have now updated the info.
Chris-TalkTalk
Message 9 of 10
Hi Mark,
  • Name
  • Telephone number
  • Alternative contact number
