VPN not working
xcaeleax
Message 11 of 11
hi, i have seen several other similar posts with the same issue.
i have been issues with connecting to my works VPN. i have spent hours already on the phone to try and resolve this and the IT team at my own office. however no-one is able to help as they cannot see that there is an issue as to why i cannot connect. i have seen that others have had this solved, your help would be very much appreciated.
thank you
10 REPLIES 10
Message 1 of 11
How are you getting on?
Message 2 of 11
Hi @xcaeleax
There are very few bugs in V174 affecting VPNs, but there are a few that may affect certain VPN clients. Which VPN client do you use to connect to your work? Do you know what VPN protocol that it uses, here are most of them:-
  • PPTP
  • L2TP-IPSec
  • SSTP
  • IKEv2
Message 3 of 11
It's running 100174 Keith
Message 4 of 11
Thanks, but what firmware is it running?
Message 5 of 11
Hi Keith, please see below:
Router: Sagemcom CS 50001   FAST 5364-3.T8
Message 6 of 11
Hi xcaeleax,
What exactly happens when you try to connect to the VPN?
Message 7 of 11
i do, i have updated my details - still require help to get connected. thank you
Message 8 of 11
Do you still need assistance with this?
Message 9 of 11
Hi xcaeleax
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Message 10 of 11
Which make/model of TalkTalk router are you using & what is its current firmware version?
