VPN
Judes45
Message 14 of 14
Desperately seeking help! I cannot connect to my Vpn ever since I changed to TalkTalk fibre. I was previously with Virgin media and had no problem there. I have tried several times with tech support on phone (very stressful!!), and no one can help!!!!! I had another try today, but was told they cannot help me, so I’m at the point of cancelling my contract as I need to be able to work from home. Any ideas anyone? Thank you
13 REPLIES 13
Message 1 of 14
Thanks for the PM and the update and please let us know if you need any further assistance.
Message 2 of 14
Hi Judes45
I'm just sending you a Private Message.
Message 3 of 14
Ok we’ll try that, thanks.
Message 4 of 14
Would you like us to send a replacement router for testing purposes to rule this out? We would also send a router returns bag so that one of the routers can be returned.
Message 5 of 14
Unfortunately,, this has not worked. Please advise what next. I need to be able to work from home..
Message 6 of 14
Hi Judes45
Please can you try powering down the router for a full 30 minutes and then testing again?
Message 7 of 14
Tested tonight and unfortunately still not working😟. Is there something else to try to resolve?
Message 8 of 14
Hi Judes45
Sorry for the delay.
Your router firmware has updated, please can you retest?
Message 9 of 14
Yes please! Will this fix it? Thank you 🙏
Message 10 of 14
Hi Judes45,
Would you like me to update your router firmware now, it can take up to 10 minutes to complete?
Message 11 of 14
Yep, that is a suitable case for updating.
Message 12 of 14
Thank you. I have the WiFi hub2 (Fast 5464-1.T4) Version SG4K100136. Don’t know if that’s the correct info?! I’ve completed my profile & await a response from Tech support. Thanks again.
Message 13 of 14
Which router do you have and which firmware version is it? If you can identify that the support team here should be able to help.
Make sure that your personal details including TalkTalk phone number and/or account number are complete on your community profile (click here) so that they can link your forum identity with your account and then wait for them to respond. Bear in mind that they won't be back online until Monday.
