Router dead
DanielL1
Message 10 of 10
As of today, my Fibre 65 router has an orange flashing light forever. There's no WiFi from it, and I can't get an ip address using a wired connection so can't access the admin console.
TalkTalk have said that they've detected a fault and an engineer will come to my street and fix it in the next 2-3 days but they won't need to come into my house.
The issue can't just be with the line though- I should be able to connect to the router without it being connected to the outside world.
I've done a reset using the small button in the hole in the back but that isn't helped.
My fear is that I'll wait 2-3 days only to receive a message telling me that the line is fine and I'll need to wait another 2-3 days for a new router.
Anyone had anything similar to this?
9 REPLIES 9
Message 1 of 10
I'm really glad to hear this and thanks for confirming 🙂
Message 2 of 10
New router up and running. Thanks for your help.
Message 3 of 10
Ok thanks for confirming and we'll check back in with you on Monday.
Thanks 🙂
Message 4 of 10
Not yet, it arrives tomorrow.
Message 5 of 10
Just checking in to see if the router has arrived?
Thanks 🙂
Message 6 of 10
Hi Daniel
No problem 🙂
Message 7 of 10
Yes please! That would be great.
Message 8 of 10
Hi DanielL1
Would you like me to send a replacement router?
Skynet_TX
Message 9 of 10
Hi @DanielL1,
The support team here on the community will be able to pick this up tomorrow, if they agree that the router itself likely has a fault they will be able to arrange a replacement for you.
