Wifi dropping out
Giraffe
Wise Owl
Message 3 of 3
I am after some help in trying to understand the likely cause of my home wifi dropping out periodically, whirring circle shows on TV. It usually happens when watching football in an upstairs bedroom.  My remedy is to close the sport app check my wifi speed which usually then shows no problems ( 20 to 30 mbps) reopen the sports app and all is again well. No set pattern to this drop out can happen after around an hour and sometimes it doesn't happen at all rather puzzling and annoying.
My router is the talktalk hub SagemCom Fast 5364-3-TB Version SG4K100206 and upstair I have added a Wifi Extender a PIX-LINK-2.4G.
Thanks in anticipation.
Giraffe
Wise Owl
Message 1 of 3
Thanks Keith for your reply. I would be interested in your further assessment. Please send me your guide. Do you send it as an attachment to your reply?
Message 2 of 3
That is certainly not the best way to extend the WiFi of a Sagemcom 5364, the name of the extender suggests that it only works at the old 2.4GHz band, which is very prone to WiFi interference.
