Wifi keeps dropping
Kennybevan111
Message 2 of 2
The last few months our wifi has started dropping. Lately its doing it every few seconds. It'll just crash to zero then go back to ~20, then back to zero.
Since a couple of days ago, I'm unable to change the channel on router.
Any help would be appreciated
Professional procrastinator
1 REPLY 1
Message 1 of 2
Hi @Kennybevan111
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
