complaint
Blackknight1
Message 16 of 16
so was upgraded to fibre , worked for a while then new router kept failing - switching it off and on again ceased to work - so replaced it with my old router which is still working but doesn't have a phone connection. Phone used to run through telephone line which defunct after upgrade to broad band.
I have been through 3 new routers all of which only flash red/orange for ever and never return to blue. ONT hub is missing 3rd green light when new routers used.
i have spent over 10 hours on phone to talk talk and no one can help. line tests completed again and again and a btconnect engineer has been sent out to waste his time as all was working which we knew
have I got another faulty router or am I missing something that no one knows
Keith Alden
15 REPLIES 15
Message 1 of 16
Just checking back in to see how you're getting on and if the team have been in touch?
Message 2 of 16
I've escalated this over to our Faults Escalation and have asked if they can contact you as soon as possible. I can't guarantee that it will definitely be today, however I have told them that you are available for a call today.
Blackknight1
Message 3 of 16
today please
Keith Alden
Message 4 of 16
When are the best times to contact you and I'll pass this over to the team?
Blackknight1
Message 5 of 16
yes please
I would just like it fixed
Keith Alden
Message 6 of 16
Thanks for confirming. Would you like us to arrange for our Faults Escalation Team to contact you directly.
Blackknight1
Message 7 of 16
According to guidance you should be able to plug them in and away you go
I also asked that could i have a router that had been tested as the previous two hadn't worked
I have spent hours and hours on this
the proceedure seems to be
1. check line
2, send a bt connect engineer
3, confirm line working
4, close file
5, repeat
I then have to request new router in vain hope that one will work and send old one back otherwise I get charged
then I get texts from talk talk telling me they've found a solution
I'm assuming the only way to fix this is cancel my direct debit and find an new provider?
Keith Alden
Message 8 of 16
no third green light on ONT box either with new routers
so they are not communicating with ONT or wifi
Keith Alden
Message 9 of 16
none of the new routers connect they just flash red all the time
Keith Alden
Blackknight1
Message 10 of 16
i think it was openreach
it did work for a while
Keith Alden
Message 11 of 16
Thanks for confirming. So all the new routers that we have sent won't connect to the ONT at all? Was your FTTP connection set up by CityFibre or Openreach please?
Blackknight1
Message 12 of 16
yes the line is working
device connected is old router DG8041W-2TS
this is working but doesn't have a phone connecter
new routers that don't work are FAST 5464-2-T4
they have a phone / digital voice connecter
Keith Alden
Message 13 of 16
Thanks for the PM. I've run a test on the line now which is clear. Which make and model of router do you currently have connected at the moment please? Have the lights changed on the router today?
Blackknight1
Message 14 of 16
updated
Keith Alden
Message 15 of 16
Good morning,
I'm sorry to hear this and we can look into this for you.
  • Name
  • Telephone number or Account number
  • Alternative contact number
