on 24-02-2023 12:32 PM
I have recently gone on to fibre 35 were i am guaranteed download speed of 35. I am only getting between 7 mbps-11 mbps download speed and a upload speed of 2-3 mbps. My go live date was 11 days ago. I have gone pass the 10 settle period. Also my fibre connection is often going off, one day it went off 13 times in one hour and 15 mins, it also goes off when using the telephone. Is it normal to have these issues when you first get fibre.
on 24-02-2023 03:03 PM
Thanks for that. Line test is still failing so I'll log this over to Openreach for investigation. Openreach will investigate and may contact you directly if they need to access your home
on 24-02-2023 02:52 PM
I Have now done that
on 24-02-2023 02:45 PM
Thanks. If you have the mark 4 then there is a test socket, you have to remove the master socket faceplate to access it
on 24-02-2023 02:41 PM
I have the MK4
on 24-02-2023 02:02 PM
Hi gazrocks,
Which type of master socket do you have? - Your guide to main phone sockets - TalkTalk Help & Support
on 24-02-2023 01:25 PM
There is no noise and i do have a dial tone. There is not test socket on the main socket
on 24-02-2023 01:19 PM
I've run a test on the line which has detected a potential fault. Are you experiencing any issues with the voice service such as noise on the line or no dial tone? Does your main socket also have a test socket please?
on 24-02-2023 01:13 PM
I have updated my profile
on 24-02-2023 01:01 PM
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 24-02-2023 12:59 PM
If you log into your router, what speeds are shown there for the internet (normally in the initial dashboard if a WiFi Hub)?
