why do i have to keep rebooting my router to get the correct speeds
Deccaman123
Message 3 of 3
Message 1 of 3
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 3
This would sound like WiFi interference, but you have given no details to go on.
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
