why is speed from router to device always slow, 6 feet away and nothing blocking signal
gedyboy
Message 9 of 9
77 to router 53-18 from there to me
8 REPLIES 8
Message 1 of 9
How are you getting on?
Message 2 of 9
To view a PM, click on your Avatar in the form and then the Envelope symbol:-
PMPM
Message 3 of 9
hi, where will i find the inbox please
Message 4 of 9
No problem @Karl-TalkTalk
Hi @gedyboy
I will PM you a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it. Collect the screenshots that I require and include them in your reply. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Message 5 of 9
@KeithFrench - Can you assist gedyboy with some Wi-Fi troubleshooting.
gedyboy
Message 6 of 9
hi, cheers, model is Huawei hg633
Message 7 of 9
Hi Gedyboy,
Keith French has a wealth of experience in all things Wi-Fi related, If you accept his offer to help, he can go through a lot of troubleshooting steps with you and make a recommendation towards a possible solution.
Message 8 of 9
This is probably WiFi interference. Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
