Awful Customer Service (Shell Migration, from 200 to Fibre 500)
noaccountability
Message 10 of 10
Got moved across from Shell, Was told I'd be moved from a 200 to a 500 package at no extra cost,because TalkTalk don't have a 200 package. Got an email to say the speed bump has been delayed and won't be in place until September. Waited, nothing happened. Called in the beginning to September, to check, had to speak to a number of people before being told it will take more time and there would be comms soon.
Waited again till the end of the month, no comms. Called multiple times got moved from team to team, you need the migration team, you need the technical team, you need the Full Fibre team, You need the voice team. Just goes round in circles, most of them tell me they can’t access all the detail on my account.
Even got dropped by the bot, said haven’t heard from you so this conversation will be saved, I replied and gave information, a few minutes later said due to no response this conversation is closed.
My account shows I’m on the 500 package but I get less than 200, same as it was with Shell.
Today someone from the technical team tried to tell me that I get 200 because that’s what I was on with Shell, TalkTalk just changed the name but I’m not supposed to get the extra speed, had to read out the email I received that states I will get the extra speed at no extra cost to me. No one at TalkTalk seems to know what they’re talking about, the irony!
It’s like they are trying to run the company into the ground on purpose, Everyone has apologised but fixed nothing. Feels like I pay them to apologise to me rather than provide broadband.
Waiting for another callback from a manager now, will get out when I can but think twice. Seems to to work fine unless something is wrong and you need to deal with them to fix something.
9 REPLIES 9
Message 1 of 10
Thanks for the update.
ken0062
Message 2 of 10
Mine has just upgraded from 200Mbps to 500Mbps just after the first billing from Talktalk  so looks like your upgrade will eventually occur
Message 3 of 10
Hi @ken0062
If you want help, you cannot use someone else's thread.
To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
TalkTalk insists on one thread per problem per customer. Please note, TalkTalk makes the rules, not me.
ken0062
Message 4 of 10
I am in exactly the same situation as you, it appears no one is able to give a straight answer on this issue
see :- https://community.talktalk.co.uk/t5/Full-Fibre/Missing-promised-speed-upgrade-after-migration-from-s...
Message 5 of 10
If you need support, please start your own thread, @Cobble123.
Cobble123
Message 6 of 10
We are not Shell customers. We are TalkTalk customers. In fact TalkTalk are actively trying to get me to renew my current TalkTalk package at nearly £50 per month, a price roughly 30% higher than virtually every other Broadband supplier.
Anyway, I’ve also been awaiting the upgrade to the 500mb speed as promised to us months ago. I’ve pretty much conceded that it isn’t likely to happen. A good job I can give my months notice at the start of next month.
Message 7 of 10
Hi @noaccountability
Alas then, the only people who can help you are the migration team. I have checked with the TalkTalk support team on this forum and they do not yet have any diagnostic access to ex-Shell customers.
Message 8 of 10
Hello Keith,
Thanks for the reply.
Same speed direct from the ONT box.
Message 9 of 10
The forum cannot currently deal with Shell customer problems. However, I will try & give you some generic technical help:-
  1. Are you using a Shell router or a TalkTalk one?
  2. Can you connect a wired (Ethernet) device to the ONT in place of the router and do a speed test from there? What speeds do you get? This will prove the speed at which the fibre is delivered to your property.
