Intermittently faulty router
Message 14 of 14
Hi Guys,
My Hub 2 is faulty. A couple of days ago, it could not authenticate with the network to get internet access, its light flashed amber and white. I tried another router in its place, and that worked OK. After a day, I put the Hub 2 back on, and it was fine. However, it has just died again with the same symptoms. With the older router on in its place, I do have service again.
Please can it be replaced,
13 REPLIES 13
Message 1 of 14
Sorry @KeithFrench
Just ordered this for you now.
Debbie 🙂
Message 2 of 14
Hi @Debbie-TalkTalk @Chris-TalkTalk
The replacement router is fine, but it did not come with a returns bag for the old router. Please could you send me one?
Thanks very much.
Message 3 of 14
Message 4 of 14
HI @Chris-TalkTalk @Debbie-TalkTalk
I had a call today saying that the router will be delivered tomorrow (Wednesday), so thanks very much to you both for your efforts with this.
Message 5 of 14
No problem Keith, have a great weekend 🙂
Message 6 of 14
Thanks very much @Chris-TalkTalk
Message 7 of 14
I'm sorry about this Keith, yes i'll order you another
Message 8 of 14
Hi @Chris-TalkTalk
The replacement 5464 is faulty. It was supplied with firmware V158, and that all worked OK.
A short while after that, it did a firmware upgrade, and it now does not show the firmware version on the login page and will no longer accept the default router password. I did a factory reset, and it is still the same. It looks like the firmware update has bricked this router. Please can you send me another one?
Message 9 of 14
No problem Keith, thanks for letting me know 🙂
Message 10 of 14
Hi @Chris-TalkTalk
Thanks for the router, Royal Mail delivered it a few mins ago. I'll connect it tomorrow & let you know how it goes.
Message 11 of 14
No problem Keith, I've ordered the router 🙂
Message 12 of 14
Thanks @Chris-TalkTalk that is wonderful service as always.
Chris-TalkTalk
Message 13 of 14
Sorry to hear that Keith, I'll order you a replacement
