Broadband keeps dropping off
Gantocks
Message 49 of 49
Hi there, Need some help.
I have spent 5 hours on "Live Chat" with "Experts" over this issue
Speed when I have it is good. However I get "Connection Unavailable" on my 2 Iphones. My Echo Dot stops playing Radio and then comes back on. My television starts buffering and that is connected by Ethernet. I get DNS issues with webpages and Pages fail to render.
I have had 3 replacement Eero6 routers.
Surely somebody, other than "Live Chat technical experts"  know how to fix this. It started on the 4th of August
I was given an appointment for City Fibre to check the cable on Thursday nobody came to the property but I was told they had checked the cabinet and everything was ok.
- 9:01
Nobody has been from City Fibre yet I get this text from you. TalkTalk Update: Hello, following on from your recent fault, we have received confirmation from City Fibre that the fault is now fixed. If you're still experiencing problems, please reach out to us using this link, support.talktalk.co.uk. Thank you. Your TalkTalk Team.
Richard
Everything is still the same. I have Packet loss 22% and above coming to the property ONT
Packet  LossPacket Loss
I also have downtime
DowntimeDowntime
I also have RX Jitter in excess of the MTJ
RX Instant Jitter and downtime packet lossRX Instant Jitter and downtime packet loss
Technical Support have transferred me to Loyalty 3 times
Connection has dropped 11 times whilst writing this
Drop off and Packet lossDrop off and Packet loss
Nothing has been fixed.
cheers Richard
If all else fails, read the instructions
48 REPLIES 48
Message 21 of 49
You will be through to an agent.
Message 22 of 49
Cheers
Is that a Live Chat or do you get to talk to somebody
Richard
Message 23 of 49
Alternatively, you can use the below future fibre chat link:
https://community.talktalk.co.uk/t5/FutureFibre/bd-p/FutureFibre
Message 24 of 49
Hi Angelique
Thanks for that
Message is “This number is accepting calls at present “
regards Richard
Message 25 of 49
Thank you for the support @KeithFrench
Message 26 of 49
The light going Red signifies that the gateway eero has lost connection with the internet. As @angelique-TT has said, the only way to resolve this is to contact the Full Fibre helpdesk.
Message 27 of 49
The provided number is for direct full fibre support.
Message 28 of 49
Hi sabelo, Good Morning.
Does this a number connect, directly, to a real person without having to select options first.
i.e a dedicated line for Fibre Support only?
Have you used the number to get directly to a human without "Live Chat"?
If it is a case of selecting options, to speak to a human, can you tell me which ones please so that I get it right.
I have a hospital appointment this morning so I will give it a go when I return
Thanks for your advice
Richard
Gantocks
Message 29 of 49
Hi Last night,  According to "Technical Support" the Cable had been checked. Two new Eeros installed and we get this.
Hardly an issue with my devices. Nothing coming in at all.
Same this morning everything disconnects
OfficeOfficeLoungeLounge
This Morning's RX Packet loss 73%
REx and TX packet lossesREx and TX packet losses
Richard
Message 30 of 49
@Gantocks, I think this matter will need the intervention of our Fibre specialist team. Kindly get in touch with them using 03451720074 Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
Gantocks
Message 31 of 49
Both Eeros are showing RED packet loss up to 82%
25/08/2025 22:22:045sup34.21...46.19/150.00Mbps49.94...58.78/100.00Mbps54.3...54.3ms100.0...100.0%0.1...0.2%43.2...47.11.1...1.142.1...71.9ms76.9...124.1ms13.8...30.6ms12.9...17.6ms
RX packet loss occurs when a network interface or router is unable to properly process or buffer incoming packets, leading to them being dropped. Common causes include network congestion, faulty hardware (cables, ports, NICs), misconfigured network settings like duplex mismatches or MTU issues
RX Packet lossRX Packet loss
cheers Richard
Message 32 of 49
Hi Ferguson, Yip at least I am not going mad.
I cannot see how it is in TalkTalk's interest to try and fix it by sending me 4 different Eero Routers.
I may be 74 but even I can figure out it is not that.  Then to tell me that all 6 devices have developed the same fault at the same time beggers belief.
Nobody from City Fibre has visited my property the check the output of the ONT .
15 years a customer and over 6K paid to them and nothing.
regards  Richard
Message 33 of 49
OK, I tried it again and got the same as you. I promise it was different earlier though, very confusing!
Message 34 of 49
Hi Ferguson I don't get that option. Calling the same number as you0345 172 0088
Did as you said Select 3 - Technical  help - say broadband connection problem - confirm it
I am then asked if I am within 28 days of my Go Live date select 1 or 2. I select 2, as I am not, and then get told I will be sent a message Ferguson.
Richard
Message 35 of 49
Ignore the option to press 1 for a text.
Message 36 of 49
You are given a series of options:  first, which service you need help with; then confirm your number; then a number of others, wait until you hear "If you need technical help, press 3." Are you not getting these options? Are you calling 0345 172 0088 as advised by Amahle?
Message 37 of 49
Cheers Ferguson I tried that, 0345 172 0088, I got 5 options, pressed 3, said broadband connection problem, confirmed it.
I was told they have changed the way they do things. We will send you a message. End call
Twice now mate
What number and option did you use if you don't mind me asking?
regards  Richard
Message 38 of 49
amahle-TT
amahle-TT
Preview
HI amahle-TT
You did not tell me what option you selected speak to a person. Or are there none?
regards  Richard
Message 39 of 49
@Gantocks
I was frustrated on your behalf at reading about not being able to get through on the phone, so I thought I would make a test call myself. I selected the option for technical support and then did not take up the offer to get a text message. I was then asked to explain in a few words so I said "broadband connection problem" and confirmed when asked. I was connected to a real live agent within moments. I explained the nature of my call and happily he was absolutely fine about it. So I honestly  don't understand why you are finding it so difficult.
Message 40 of 49
Hi there I can see that on the above thread you included your account number, kindly remove it as this is a public platform. Thanks
