Can I keep my traditional landline phone with Full Fibre?
on 11-09-2023 10:05 AM
Message 15 of 15
Currently on Fibre 65 but as my contract runs out in a few months I'm looking at the F500 package to take advantage of the tri-band Eero. I'm sure when I looked into this a few months ago, there was an option to have a digital voice adapter which plugged into the Eero, which my traditional hand set phone would then plug into. However, I'm no longer seeing that option and only stuff about the digital voice app, which if I understand correctly means I can use my mobile with my landline number without having the physical adapter box (or am I wrong on that?). That said, I dont really want to use my mobile as my 'home phone', and would rather keep my traditional hand set. Call me old fashioned I know.
Can anyone please clarify the situation here please?
On another related topic, as I understand it, if I do use a physical voice adapter, would that mean I would then have no spare ethernet ports to plug devices into? IE....My main PC currently sits near our modem router and connects via ethernet cable.
Thanks for any assistance.............Tony
Labels:
- Labels:
eero
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
14 REPLIES 14
on 14-11-2023 09:31 AM
Message 1 of 15
I would check your order with our fibre teams if you are not sure if you included Digital Voice, to make sure you requested this.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-11-2023 09:23 AM
Message 2 of 15
I dont think that was an option on the ordering page.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-11-2023 09:19 AM
Message 3 of 15
If you ordered fibre with digital voice, then a digital voice adapter will be included with the equipment that is sent.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-11-2023 09:15 AM
Message 4 of 15
I finally bit the bullet and ordered the FF150 package (via the website) with the extra EERO and the TV package. However, I'm still not clear on whether the Digital Voice Adapter is included. On the email confirmation of the order, it lists the equipment that will be sent, but no mention of the VOIP adater?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-09-2023 08:45 AM
Message 5 of 15
Hi TD1966
It will be the full Eero.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-09-2023 08:36 AM
Message 6 of 15
Thanks for all the info thus far. Now looking at FF150 but with a second Eero to form a mesh network (one upstairs, one downstairs). TT have the option for a second Eero for £6 per month, but does anyone know if that is the full Eero or the extender (ie no ethernet ports)?
I'm assuming that if it does have ethernet ports, then I can use those to plug in devices eg PC, and that the 2 Eeros communicate via Wifi?
Thanks..............
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-09-2023 12:44 PM
Message 7 of 15
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-09-2023 11:54 AM
Message 8 of 15
Thanks for the good news.
So - If I understand correctly, the Digital Voice Adapter would plug into the second ethernet port on the Eero, the first port being the cable from the ONT.
If so, as suggested in an earlier post, I could use a cheap switch (eg TP-Link TL-SF1005D), I could plug the DVA and also an ethernet cable to the static Personal Computer there?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-09-2023 10:13 AM
Message 9 of 15
Hi TD1966
Thanks for your post.
I have checked your account and the Voip option is available and the Digital Voice adaptor comes with the Eero as part of the package, call the loyalty team on 03451720088 The will be able to see what options are available.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-09-2023 03:13 PM
Message 10 of 15
No point buying anything if VOIP is not provided on the service. The best thing to do is ring the full fibre team and speak to them and they will confirm whether or not VOIP is available to you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-09-2023 03:10 PM
Message 11 of 15
I'm not sure that is still the case. As I said in my first post, the only options you can pick currently make it clear there is no landline. Just data.
Have TT moved the goalposts and no longer provide the free VOIP adapter? If so, I guess I could buy one myself?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-09-2023 02:48 PM
Message 12 of 15
If the Eero is supplied and you request VOIP then they should supply the adapter.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-09-2023 02:10 PM
Message 13 of 15
Thanks for the reply. I may revisit the speed as F500 does sound a lot given that my current fibre 65 package works well. Perhaps I'll go the F150 option?
As for the Grandstream adapter, is that something Talktalk will provide for free, or do I have to purchase one?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
11-09-2023 01:37 PM - edited 11-09-2023 01:43 PM
Message 14 of 15
Lack of ethernet ports is easily fixed with a small switch about £20 from Amazon. Yes your traditional copper service will be migrated to VOIP and then if you have the Eero router you will require the Grandstream adapter for your phone. If you have the HUB2 it has a telephone adapter built in and has more ports. Just bear in mind that if you have copper extensions in the house they will no longer work. The mobile App is an added function if you want to use your landline on your mobile, but not essential.
To be honest do you really need the Tri_band Eero not many device support WiFi 6 and with 500mbps internet service it is extremely unlikely you will saturate the Wifi or the download speeds.
I'm on standard Wifi on a FTTP 65 circuit and not once saturated my connection and I work from home developing apps and uploading, downloading lots and watching streaming TV.
You will need to confirm who will install the FTTP circuit as City Fibre, to my knowledge, still do not support VOIP on their circuits. Not sure about other providers other than BT who do provide VOIP.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- can my parents add a landline to there full fibre account in Full Fibre
- Upcoming copper line charge in Home Phone
- Moving Home VOIP not available - why in Fibre
- I have FTTP and a copper landline. Why can i not run a line connection test? in Full Fibre
- Change to digital voice - a bit of a disaster in Home Phone
