Friday - last edited Friday by ferguson
My FTTP was installed yesterday and its working fine, when I checked the eero app i saw 4 connected devices three i recognised and one called Commscope which i didn't does anyone here know what it is?
I did search and find *removed* but still haven't a clue why i am seeing Commscope in the list of connected devices.
I hope someone here can help and thanks in advance if you can.
Answered! Go to Solution.
Saturday - last edited Saturday
Post edited 😉
Thanks Ferguson
Saturday
And I saw you on thinkbroadband, it came up when I was searching for solutions! And I doubt "millions" of Freesat boxes, but point taken.
Saturday
Hurrah! And thanks for sharing. 🙂
Sorted.
Thanks to a couple of great members over at Thinkbroadband (hope i am allowed to post that) we finally got to the bottom of it.
I have a Freesat set top box which records and streams i tried to stream Netflix on it after blocking Commscope and it failed with an internet connection error popping up i unblocked Commscope and it worked again.
I hope this helps others in the future as there are *millions of these boxes out there.
Who manufactures freesat boxes?
As of 2024, Arris [ARRIS GLOBAL LTD] (Part of Commscope) Make the main boxes for Freesat
Current Model Numbers are UHD-X-**** these are smart boxes that can record multiply channels from the live TV broadcast and access via internet to Netflix, iPlayer.
*as Ferguson points out below that may be a bit of an exaggeration 😉
Saturday
No i will try that thanks
Saturday
The first thing I did was looked at mine, but no. I think we have hit a bit of a dead end for now. Have you tried reaching out to eero support directly?
Could i ask any members reading this to check their eero app and see if Commscope is listed under "devices online" or offline thanks.
Friday
Were the screen shots of no use?
Friday
I am very new to this i am not sure what you mean by filters.
I have taken the screen shots below to try to help members it says Activity 0 but i am sure yesterday it was connected and running.
Friday
You could try using the filters on your eero app to at least narrow down how the unknown device is connecting. I have removed the link, it is best not to post in public if there is the slightest suspicion.
