on 07-12-2024 06:10 PM
I have the old Fibre 65 which comes over a standard BT copper line. I can now get Full FIbre 150 in my area. What does the upgrade involve?
Will they rip out the existing BT line and drill new holes from the outside to bring the fibre inside?
Can I stream TV (FIrestick, Roku, etc.) with Full Fibre 150 ?
Cheers,
Answered! Go to Solution.
on 08-12-2024 09:39 AM
Thank you!
on 07-12-2024 06:33 PM
This should help you understand the process and yes you can still stream using your devices.
https://community.talktalk.co.uk/t5/Articles/Your-Fibre-150-250-installation/ta-p/2569618
