Connect DECT phone via LinksysPAP27
PeterR7
Message 2 of 2
I have recently installed FFTP with digital voice and a LinksysPAP2T box to which I can connect the DECT base station and from that box via a previously used (to connect to a TalkTalk FTTC service) ethernet cable to an ethernet port on the recently provided full fible with digital voice TalkTalk router. How do I make that work? If not possible, how can I connect the DECT to one end of the ethernet cable and connect the other end to a standard BT-style phone socket to go in the green phone socket on the TalkTalk FTTP router? Running a new phone extension line from FTTP router to the DECT installation is not feasible).
PeterR
1 REPLY 1
Message 1 of 2
Hi @PeterR7
The LinksysPAP2T would seem to be a phone converter to SIP, it is not the way that Digital Voice is implemented by TalkTalk. Which make/model of router do you have?
If it is the Eero, then you should have been provided with a Grandstream ATA for Digital Voice, if you have the Hub 2 then you simply connect the DECT base station to the phone port on its rear panel.
