DVA not working on new full fibre install
Willb67
Message 3 of 3
I cannot get my DVA to work with my eero 6. New install with everything else working ok. Have tried all the suggested fixes at this end. Can someone help?
Chris-TalkTalk
Message 1 of 3
Hi Willb67,
How are you getting on, have you tried Keith's suggestion?
Message 2 of 3
What lights are on the DVA?
Have you tried connecting the DVA directly to the oONT in place of the Eero and pressing the reset button? If that works then reconnect everything as it should be.
