Different router will not connect
Carolinebiscuits
Message 8 of 8
Talk talk router had died, I have a TP link archer a7, but unable to get it to connect. I have tried PPoE and dynamic up in the setting on the WAN port, set the vlan id to 101 and still no joy. Any help would be really appreciated
7 REPLIES 7
Message 1 of 8
@Carolinebiscuits, just checking to see if you have managed to get in touch with our Full Fibre team regarding the router issue.
Message 2 of 8
The problem could well be that with CityFibre a particular profile must be set by the Full Fibre Helpdesk before it has any chance of connecting. I do not know which profile needs to be selected for a 3rd party router, maybe "T", but that is just a guess.
If the TalkTalk router is dead, it can be replaced, again, probably from the FF Helpdesk.
Message 3 of 8
Hi there @Carolinebiscuits Please contact the full fibre team on 03451720074  - VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed they will run diagnostic checks to detect the fault and advise you further.
Message 4 of 8
City fibre, I think it’s the cable that came with it. I have tried a cat6 and still no joy. I can see packets going out but nothing coming back. Just tried another router with openwrt and still no joy. All four lights are on the ONT
Message 5 of 8
I wouldn't have thought so. I take it you have connected the WAN port to the ONT by an ethernet cable of at least Cat5e standard? Dynamic IP should do it. Just to check: do you have an Openreach, or City Fibre connection?
Carolinebiscuits
Message 6 of 8
Thanks, that’s what I have been trying. Could the router be too old?
Message 7 of 8
Have you seen these instructions?
https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
Bear in mind that all fibre, fttc and fttp are fibre settings. This often catches people out who are on fttc packages.
