Digital Voice and App
Nadeem-Aslam
Message 64 of 64
Today i had my internet upgraded to full fibre, I have a Hub 2 but i won't be using it as i have a more advanced personal router and will keep the Hub 2 as backup.
The openreach engineer just told me to test internet which we did with Hub2 plugged in to avoid any possible issue, but he never checked if the phone worked. I was hoping to just use the Digital Voice App, but i can't see where to register mobiles etc - maybe as details not updated in my account. Also don't know if i can get a digital adapter tot use with my own router then i could use hand sets or do Talk Talk have list of VOIP phone they support.
On a side note - no fault of Talk Talk the open reach engineer has very muddy boots left mud all over laminate - luckily we'd put down protection on our carpet otherwise he'd have soiled 1100 pounds worth of flooring - i don't know if you can support but i'd like to raise as complaint most engineers. I've ever had either ask if ok to come in with boots or the have protectors they put over their boots.
63 REPLIES 63
Message 41 of 64
Thank you. I've raised this to our Product Team to investigate.
Message 42 of 64
You're welcome 🙂
Hopefully TalkTalk makes that page easier to find and gets it working correctly with all web browsers.
benny55
Super Duper Contributor
Message 43 of 64
Well done 'theblackcat' a breakthrough at last.
Much appreciated.
Message 44 of 64
Thanks theblackcat and glad to hear it's now resolved Nadeem, apologies for any inconvenience. Thanks also for your feedback.
Nadeem-Aslam
Message 45 of 64
Chris i can confirm the above worked and when i call my land line it and receive it on my digital app- thank you for your support and also @theblackcat for sending me PM
Chris you might want to highlight the issue to development teams or check why the issue occurs and also abit hard to confirm if deregister of my account was part of fix
theblackcat
Message 46 of 64
I originally sent @Nadeem-Aslam this as a private message, since I didn't want to bump their thread and potentially delay replies from the staff. But since they've replied back that it worked for them I'll post about it here now too.
When I attempted to access the page to enable the digital voice app from my mobile or my laptop using the Firefox web browser I'd be reloaded back to my dashboard. But after logging in via Chrome on my laptop I could access the page and enable the setting. Then I just needed to click on the set/re-set password button in the app.
You'll find the setting to enable the digital voice app on this page - https://www.talktalk.co.uk/my/voip-app
Message 47 of 64
OK thanks. I'll look into it and get back to you
Nadeem-Aslam
Message 48 of 64
Hi Chris
Well it was just 5 mins before i posted bump, but it is unregistered now and i've just reregistered - Still can for life of me find the Voice App register section can you check if it's there or not on your end - happy to go through security if required.
Seems like not only myself but others have same issue too and it's not being resolved
benny55
Message 49 of 64
I’m interested in the outcome of this as I’ve been waiting for months to get a resolution to an identical situation.
Message 50 of 64
Hi Nadeem
How long ago did you check as it's showing 'not registered' now?
Nadeem-Aslam
Message 51 of 64
Bump as requested - i can still log into my account as of this morning and still no change or digital app etc
Message 52 of 64
I don't think you'll get an email but you could just try logging in now and again, when it's deregistered you won't be able to log in and you'll have to reregister
Nadeem-Aslam
Message 53 of 64
Ok thank you - so will i likely get an email to say register for my account
Message 54 of 64
Thanks for answering the security questions. I can see that there's an issue with your My Account so I've passed this to a back office team to have your My Account deregistered, you should then be able to reregister and the issue will hopefully be resolved. I'm not sure if this will resolve the digital voice app issue (I'm hoping it will) but I think we need to do this first anyway.
This can take up to 10 working days but it should be much sooner so could you bump the thread in 72 hours and we'll check how it's going
Message 55 of 64
Hi Nadeem,
I've sent you a PM to confirm some details
Message 56 of 64
Hi Nadeem-Aslam,
I think I may know what the issue is with the digital voice app, I'm just looking into it.
Nadeem-Aslam
Message 57 of 64
I tested the phone on the TT Router and it works fine - but as mentioned i don't use TT router therefore can't plug in physical phone - i know with eero you provide some digital phone adaptor - is there no option to send one of them out ?
My account correctly reflects i'm on Fibre 65 VOIP, but i still can't see option to register the Digital Voice app as per instructions.
Also it appears my free upgrade actually extends my contract that was not clear on email or even mentioned - if i'f know that was case i might have signed upto Fibre 150 not sure if there is VOIP on that service. Really i'd rather not have extended contract but if thats how you do things which is slightly disingenuous i may as well consider an upgrade if the price is right. Which means i'd get eero and digital voice adaptor
Message 58 of 64
I just think it's worth trying to make sure that the digital voice service is working OK
benny55
Message 59 of 64
@Nadeem-Aslam wrote:
Will try latter - but i don't want to use hub long term - it would mean reconfiguring lots of devices plus my router has advanced functionality i want to keep - i'm happy to use the app as i'm deciding not to use your hub - will get back to you.
We will be upgrading your home with a brand new Full Fibre connection that’s faster and more reliable, for free. It will also include our new Digital Voice phone service.
But email stated i'd get digital voice - i'm assuming my account will eventually get updated allowing me to use the app
Don’t hold your breath on this.
I am in an identical situation having agreed to an upgrade back in May, still waiting for the Digital Voice App activation process.
See this;
https://community.talktalk.co.uk/t5/Home-Phone/Where-is-the-Digital-Voice-App-selection-option-on-My...
Message 60 of 64
