Eero 6Pro reset
spaarks11
Message 14 of 14
Eero 6Pro, supplied a couple of months ago, has stopped working.
The LED is quick-flashing yellow(-ish).
Holding the reset button for 30secs does nothing.
I have it connected to the supplied Eero power supply.
Anything else I can do to get it working?
Dinny
13 REPLIES 13
Message 1 of 14
Yes the Pro6 was supplied for free in order to fill in a small weak-signal spot. It failes (see separate thread "Eero 6 Pro reset").
The replacement was an Eero 6 and I returned the faulty Pro6.
Dinny
Message 2 of 14
Hi @spaarks11
You were diddled if you were sent an eero 6 as a replacement for the eero Pro 6. The Pro 6 is a higher spec than the 6. Please can you confirm?
Message 3 of 14
Sorry, I used the wrong term.
It is the recently supplied Eero6 (replacing the faulty Pro6). I added it using the Eero app., and assume it is part of the mesh.
The gateway has reverted back to Ch42, where my neighbour's Sky router is.
Dinny
Message 4 of 14
Can I just confirm @spaarks11, is this really an eero Beacon that you are adding or an eero 6 or a Pro 6? The way I understand it, the eero 6 or Pro 6 should be added as an extender, because the Beacon is WiFi 5, not WiFi 6. Thus reducing the WiFi speed.
spaarks11
Message 5 of 14
Before installing the new Eero6 beacon I noticed the gateway had again switched to Ch104 (in the DFS band), and like my mobile(s) were connecting to that channel over nearly all my flat, with a solid 150Mpbs. After 24 hours it was still on Ch106 and a solid 150Mbps.
(Previously, while the gateway was on Ch42 the mobile often switched to the 2.4GHz with a speed of 45Mbps).
Today I installed the new Eero as a beacon the speed went down to around 95Mbps when connected to the beacon - still 150Mbps when near the gateway. I cannot find a way to determine if my mobile is on the gateway or the beacon.
I will keep an eye on it over the next couple of days.
100 to 144100 to 14436 to 6436 to 641 to 111 to 11APsAPs
Dinny
Message 6 of 14
Hi @spaarks11
Thank you.  I will check in again with you on Friday to see how you are getting on.
Message 7 of 14
Thank you. I will let you know. We live in hope!
Dinny
Message 8 of 14
Hi @spaarks11
The replacement eero is on the way, please allow 24-48hrs for this to arrive.
Let us know how you get on.
Message 9 of 14
Yes please send replacement.
The faulty unit ser.no. KCAF-082C-1J74-Y3S2
Dinny
spaarks11
Message 10 of 14
Please disregard my words "possibly caused by the ongoing network issue".  Nothing to do with that issue.
Dinny
Message 11 of 14
spaarks11
Message 12 of 14
OK, I've done that. Just the same.
Incidentally I was supplied with this Eero to cover a low-signal area possibly caused by the ongoing network issues.
Dinny
Message 13 of 14
Hi @spaarks11
That sounds like a power unit/eero fault, as that light behaviour suggests an unapproved USB Type C power source being used. Can you turn it off for 30 mins & then connect it to a totally different electrical outlet socket & see what that does? If it is still the same, I will ask TalkTalk to replace it for you.
