Ethernet switches for eero6
EricsL
Message 2 of 2
Just been connected to full fibre. Only one Ethernet connection on week box . Disgraceful. Will an Ethernet switch work ok with it?
1 REPLY 1
Message 1 of 2
Yes, you'll want a gigabit Ethernet switch, something like this one:-
https://www.amazon.co.uk/NETGEAR-Ethernet-Unmanaged-Internet-Splitter/dp/B07PYSNSDD/ref=sr_1_6?crid=...
