on 01-07-2025 04:43 PM
Hiya,
It seems my router has developed a fault a few days ago, wifi is working fine with no issues however all of the ethernet ports keep dropping out repeatedly as all my hardwired devices keep showing as disconnected/reconnected.
To check that its the router and not a wiring fault i've tried running some spare patch leads directly from the router ethernet ports to the devices that are normally hardwired and still having the same issue.
I suspect that the router is faulty and a replacement is needed, can this please be arranged?
Cheers
Tom
on 02-07-2025 05:43 PM
I do understand your concerns about this matter however since you are contracted to our Full Fibre plan, our Full Fibre specialists will be able to assist with this matter.
on 02-07-2025 05:25 PM
Yeah, that wasnt really helpful to be honest, not on your part or the representative that I spoke with. More the fact that I am being told since the wifi works on the router (even though the ethernet ports dont) that I would have to replace the router at my own expense.
Unfortunately I wont be prepared to pay TT to replace a device that clearly is faulty (as in 50% of it works - how it can be classed as working with ports that dont work is beyond me) I'd rather put that money towards a proper gateway i.e. Ubiquiti and get rid of my phone rather than have another sub-standard router again (around 7 routers in 11 years with TT).
I presume that if I purchase a proper gateway it would work on your service or would you have to supply login credentials?
Tom
on 02-07-2025 02:09 PM
@TomLO1, thank you for this. We have further investigated the matter and have noticed that this will need the intervention of our Full Fibre specialist which I will strongly advise for you to get in touch with the team using 03451720074 Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed.
on 02-07-2025 02:00 PM
@siphosethu-TT Yes I am
on 02-07-2025 08:25 AM
Thank you, please confirm if you are currently at home so we can get started right away. 😇
on 02-07-2025 07:57 AM
on 01-07-2025 05:02 PM
Hello there @TomLO1, let me look into this matter for you. Before continuing any further, please update your community profile and add your landline number and/or account number so your account can be identified. Please don't post personal information here.
https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
