Fibre Connection Box has solid red light
rijedo
Message 17 of 17
Since this morning we have been without broadband. I've looked at articles and none refer to the ONT box that we have. The "status" light flashes green slowly and the "alarm" light is solid red. Our ONT box is connected to an eero router. I've switched the box of for over half hour and no change. Can anybody help? Thanks
16 REPLIES 16
Message 1 of 17
I'm really glad to hear that the fault has been resolved and thanks for letting me know 🙂
Message 2 of 17
Hi Michelle, freedom fibre came today and were very helpful, they changed some cabling etc and we're back up and running. Thank you for your help in getting this sorted so quickly 🙂
Message 3 of 17
Hello again,
Just checking back in to see how you're getting on?
Michelle 🙂
Message 4 of 17
The team have advised that an engineer has been arranged so we'll check back in with you to see how you're getting on.
Message 5 of 17
Good afternoon,
Great thanks for confirming. They confirmed that they had escalated the fault and we should hopefully receive an update soon.
Message 6 of 17
Hi Michelle, they have thanks, just waiting for them to call me again. Just to let you know I went outside to look at the cable coming into the house and a plastic cover says "freedom fibre"
Message 7 of 17
I believe that the team have now made contact.
Message 8 of 17
Hi again,
The team has confirmed that they will pick this up and will be contacting you shortly.
Message 9 of 17
Thank you, I'll keep a lookout for your update
Message 10 of 17
I've passed this over to our Faults Escalation Team now and I will post back as soon as I receive an update. It's possible that the team may also try and contact you directly.
Message 11 of 17
To tell you the truth we didn't look at the side of the van. Talktalk were in our area and asked if we wanted to upgrade to full fibre and an engineer came and installed the fibre optic cable and the rest of the equipment. I hazard a guess that talktalk who I presume commissioned the work would have some idea who completed the work
Message 12 of 17
Hi again,
Sorry for the confusion, was this definitely Openreach and not Freedom Fibre?
Message 13 of 17
Hi Michelle
Thanks for getting back to me. It was openreach.
The "status" light flashes green slowly and the "alarm" light is solid red. The only other light that is green is the "GE1" light. I've switched the box off for over an hour and have reset with no change. Can you help please? Can you send out an engineer to look at it. My account number is in my profile or I can send it you now.
Message 14 of 17
I'm sorry for the delay. Can I just confirm, was your connection installed by CityFibre or Openreach?
rijedo
Message 15 of 17
Hi thank you for your reply and for the article. I read it yesterday and followed instructions re: checking cables etc but no joy. I've updated my profile with account details, so thanks for that.if there's anything else you could suggest I'd appreciate it. Thanks again
Gliwmaeden2
Message 16 of 17
Did you check this article?
https://help.talktalk.co.uk/ONTlights
They suggest check your cables, @rijedo.
Staff won't be back before Monday.
Ensure that you have completed your community forum profile details, with your account number in the telephone number/ account number box in Personal Information.
Go via your avatar/name; settings; drop down menu.....SAVE CHANGES.
