on 01-03-2024 03:36 PM
I need some advice, please. I have just signed up for TT full fibre and understand I will get an EERO 6 router. However, I see that this device only has two ethernet ports. I am currently using the Talktalk hub provided for my current Fibre 65 FTTC. This hub has four ethernet ports. My home is wired with ethernet cables which connect my PC, two smart TVs, a Sky Q box, two Sky Q mini boxes, speaker system, network printer, sound system and two range extenders. All four ethernet ports are in use on the TT hub and two unmanaged ethernet switches are used to provide the additional ethernet connections required. WiFi is only used for phones and tablets. Am I going to have to buy more equipment to be able to retain my preferred ethernet connectivity?
Thank you.
on 12-03-2024 02:39 PM
Hi paullus
The order includes 1 EERO
on 01-03-2024 04:18 PM
I've just educated myself regarding my question and it's simply a case of buying another unmanaged ethernet switch if necessary.
I've opted for the Full Fibre 150, please can someone tell me how many EERO 6 devices I will receive?
Thank you.
