on 11-11-2024 09:17 AM
I recently switched from fibre 35 to full fibre 150. It works perfectly downstairs but the speed upstairs is quite slow, and seems to disconnect and reconnect to devices in my back bedroom. I didn't have this issue when I had fibre 35, the connection was fine throughout my house, and I have the eero router setup in the same place as my old router so I'm not sure what's causing the issue.
on 11-11-2024 11:50 AM
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
