Full fibre 150
Steveowen1000
Message 5 of 5
Hi all,
I have upgraded to Fibre 150 this week, however the provided Eero router does not have the best coverage. On installation the Openreach engineer suggested I request a Hub2 router as this would allow me to utilise the poweline adapters I currently use.
The new router has arrived today, do I simply swap out the Eero router for the Hub2 or do I use them in tangent?
Many thanks
4 REPLIES 4
Message 1 of 5
Hi Steve,
Thanks for the update.
Michelle 🙂
Message 2 of 5
Hi Keith and Chris
Keith, thank you for the feedback/support, yes I have both Routers but will now send the Eero back based on your response.
Many thanks
Steve
Chris-TalkTalk
Message 3 of 5
Hi Steve,
Welcome to the Community
I can see that Keith has answered your question. If you need further assistance just let us know
Message 4 of 5
Do you have both the Eero & the Hub 2 now? They are not really designed to work together, I would therefore recommend that you just use the Hub 2.
