Full fibre 65
silverbird63
Super Duper Contributor
Message 75 of 75
Hi we have upgraded to full fibre 65 with voip from fibre 65. We go live on 06th September 23, not received new router yet.
Please help CEO.
Thank you
Not an expert at much just like to learn about as many things as I can
74 REPLIES 74
silverbird63
Message 61 of 75
Thanks Chris for the explanation but we were never told this we were told we were just getting a better speed say 70 instead of 50.  Is this right.
Message 62 of 75
Aw, don't be worried. The process is relatively painless. The engineer should arrange a spot for the internal unit which is convenient for you, as long as it is within easy reach of where the fibre cable reaches your home. Have a look at this for an overview:
https://community.talktalk.co.uk/t5/Articles/How-Full-Fibre-is-installed/ta-p/2555166
silverbird63
Message 63 of 75
The person that got us to upgrade from ordinary full fibre 65 to this extra boosted one that will be faster he said.
Getting worried now. Thank goodness the phone calls a recorded.
Thank Chris
Message 64 of 75
Who told you that? They do need to come inside to install the ONT (Optical Network Terminal) which then connects on to your router. The worst that can happen is that you may be unable to use your phone for a day.
silverbird63
Message 65 of 75
We were told everything would be done outside, and the landline phone would plug into the router. This isn't very good, is it.
Message 66 of 75
Hi silverbird63,
If the router doesn't arrive tomorrow then the engineer will set up your service with your existing router. The router should arrive tomorrow but if it doesn't we will have to raise it as an escalation in which case you would usually receive the router the following day
silverbird63
Message 67 of 75
Hi Chris
Back home. Still no sign. What is the contingency  plan for tomorrow when the engineer comes out and there's no router?
Message 68 of 75
There's no reason to sit in all day today, I'll just update the thread when I have any more information
silverbird63
Message 69 of 75
Ok but we cannot sit in all day we have an appointment. Nothing so far from TT.
Cheers Chris
Message 70 of 75
No problem, I'll check again later to see if the order is progressing
silverbird63
Message 71 of 75
Thanks Chris
We have the engineer coming tomorrow. We were told the 6th September 23 between 8 and 1. That was on 22nd August. Although we haven't received a verification email. We feel a bit lost a d worried. We have been customers since 2007,, hopefully that holds some value
Thank you again
Message 72 of 75
Hi silverbird63,
The order for the router has been created, I'll check later to see if it's progressed.
silverbird63
Message 73 of 75
Just the ordinary router for full fibre. Not the VoIP one.
Message 74 of 75
Which router do you have presently? It will be quicker to chase this if you contact customer services directly.
