on 31-01-2024 06:25 PM
I’m eligible for an upgrade to full fibre 150. As I understand it, this would require me having an eero 6 router. At the moment I have a talktalk WiFi hub, but need two additional access points to achieve a WiFi signal to the garage and the back of the property. Would the eero router be compatible with these access points or would the router itself provide the extra range.
on 01-02-2024 03:02 PM
The 5464 has the telephone port so you'll be able to use it to connect to the Internet but not for digital voice
on 01-02-2024 02:54 PM
Hi Chris
I have the Sagemcom 5364. There is no telephone port that I can see.
on 01-02-2024 08:51 AM
Hi ricksmith
If you have a Sagemcom wifi hub it will work with your new service but it would have to be the wifi hub 2 if you have digital voice (VoIP) as the wifi hub 2 has the telephone port
