Full fibre installation
F10rrell
Chat Champion
Message 25 of 25
Hello
@KeithFrench
We had #full fibre installed on Friday by MJ QUINN the router wasn't checked correctly and we have had no internet or WiFi since! The previous package was disconnected on Friday and the new one started but we are unable to use anything
Lesley
Lesley
24 REPLIES 24
Message 1 of 25
Thank you so much @KeithFrench
Message 2 of 25
Hi @F10rrell
You will likely experience Wi-Fi reception issues that you didn't have before, because the Hub 3 is located next to the TV. Your best bet now is to consider using a long Cat 6 minimum Ethernet cable to move it away from the TV. I like to run it around skirting boards in self-adhesive white plastic trunking. Of course, this is all work that you would not have needed to do if only MJ Quinn had put the ONT where you asked them to.
Message 3 of 25
Thank you so much for the update that everything is working okay.
F10rrell
Chat Champion
Message 4 of 25
Openreach have now been and connected everything, although they have left the ONT and router by the TV. Everything does seem to be working!
Lesley
Message 5 of 25
You are most welcome and i am most certain the engineer will have that sorted for you:)
Enjoy the rest of your day and take care.
Message 6 of 25
I'm hoping everything will now be resolved tomorrow and I will have WiFi back and I'll be able to use all the devices and equipment as before - better than before!
Thank you.
Lesley
Message 7 of 25
That is okay, thank you for double checking:)
While i still have you online, i would like to confirm is there anything else that i can assist you with?
F10rrell
Chat Champion
Message 8 of 25
I have double checked, with photo, and can now see it is a Hub 3! Apologies for the confusion everyone!
Lesley
Message 9 of 25
Thank you so much for updating us an engineer visit has been arranged for you, hopefully the issue will be resolved.
F10rrell
Chat Champion
Message 10 of 25
The new router may be a Hub 3 in the older case.
Lesley
F10rrell
Chat Champion
Message 11 of 25
Just had a call from customer services and they've arranged for an openreach engineer to come tomorrow morning.
A router arrived in the post this morning, even though I wasn't sent a tracking number, but it's not the Hub 3!
Lesley
F10rrell
Chat Champion
Message 12 of 25
Thank you @Lorrainef That's good news
Lesley
Message 13 of 25
Thanks very much @Lorrainef.
Lorrainef
Message 14 of 25
Good morning I've escalated this into the management team for that area, they'll take a look at what's gone on and will get someone to pick this up and reach out.
Message 15 of 25
Hi @Lorrainef
Despite contacting the Full Fibre helpdesk, this failed installation is a total disaster. Please can you see if there is anything you can do to address these three main issues for @F10rrell, namely:-
  1. The installation is still not working, or it is not authenticated, as an Ethernet connection from a laptop directly to the ONT proves that no WAN IP address is being allocated.
  2. The new Wi-Fi Hub 3 order has yet to provide the customer with a tracking number.
  3. The installer from M.J. Quinn has not put the ONT anywhere near where the customer requested it. He obviously has no knowledge about Wi-Fi, putting it right by the TV downstairs. I can easily pull up loads of websites to back me up in saying that this is just about the worst place to put a router (apart from a kitchen).
Thanks very much.
F10rrell
Chat Champion
Message 16 of 25
Apparently my new full fibre connection is activated. However, if I connect a laptop via an Ethernet cable to the ONT, the laptop reports no internet connection. I have turned the ONT off for over 30 mins, that makes no difference at all. Therefore, the fibre might be OK, but its access to the internet is blocked, probably due to an authentication issue. Test on the laptop reveal that it is not being allocated a WAN IP address by your network. In addition to this, I still have not been provided with a tracking number for the router. Finally, there is the issue that M.J. Quinn ignored my request to put the ONT upstairs & just installed this where it was easiest for him, right by my TV. I have been reliably informed by your Community Star @KeithFrench, that this is just about the worst place in a house for Wi-Fi reception. I have now been out of service since Friday and this totally unacceptable.
Lesley
F10rrell
Chat Champion
Message 17 of 25
The full fibre has now been activated but we still have no WiFi as the router has not connected. Also we have not yet been sent a tracking number for the new router that I was told was on the way!
Lesley
Message 18 of 25
Thanks @Lorrainef
Message 19 of 25
Thank you Keith, I'll get the team to take a look at it.
Mandisa-TT
Message 20 of 25
Thank you @KeithFrench
