Full fibre installation
F10rrell
Chat Champion
Message 25 of 25
Hello
@KeithFrench
We had #full fibre installed on Friday by MJ QUINN the router wasn't checked correctly and we have had no internet or WiFi since! The previous package was disconnected on Friday and the new one started but we are unable to use anything
Lesley
Lesley
24 REPLIES 24
Message 21 of 25
Hi @Mandisa-TT
It now seems that this may be getting resolved, as TalkTalk did not activate the Full Fibre, which they have done. @F10rrell only has the Wi-Fi Hub1 (Sgaemcom FAST5364), which is totally incompatible with Digital Voice (VoIP). She should be provided with the new Wiu-Fi Hub 3 as it is the standard router. However, an agent kept telling her she had the latest router, which is clearly not the case. Apparently, there is a hold on the router order. I do not know why.
This is going to leave the customer without DV. Hopefully, they might get broadband via the old router connected to the ONT, but that keeps losing its configuration, which is far from ideal.
There is also a problem with the location of the ONT. I suggested to the customer previously that it should go where the old router was, as the WiFi coverage there was good. MJ Quinn who did the installation, put it downstairs right next to the TV, which is the worst possible location, as the electronics in a TV, whether it is on or off, dramatically affect WiFi reception.
@Lorrainef can you help the customer in any way, as she has had a really bad experience with TalkTalk/MJ Quinn?
Mandisa-TT
Message 22 of 25
Thank you so much @KeithFrench
Message 23 of 25
I'll read through this & respond after lunch.
Mandisa-TT
Message 24 of 25
Hi @KeithFrench any advice will be appreciated.
We can wait for KeithFrench or you can call through to our Full Fibre Team and they will be able to assist you.
Contact Number: 03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
WEB MESSAGING - Mon-Fri: 8am-9pm; Sat: 8am-7pm; Sun: 9am-7pm
Another option is to use the below link to chat to our live chat advisors who are always ready to assist with your issue.
