on 06-10-2024 08:59 PM
Hi all. The gaming and conferencing setting on the eero app seems to have disappeared. No option to turn it on anymore for my son with his Xbox. It used to be on there. Any advice please.
on 07-10-2024 09:33 AM
Thanks Keith, no problem. I also checked the app and I couldn't see it so I'll let you know what the devices team advise.
Hi Keith. I can't remember. Lol. It was a few months ago and in the app it just said Gaming and conferencing. You could switch it on or off.
It used to be there and just disappeared.
Regards Lee
on 07-10-2024 09:29 AM
I am busy at the moment testing the Sagemcom new firmware & may not be able to look into this with the eero until later today, or tomorrow.
Hi @leenineplus
Where in the app was this QoS setting & I will first look in my own documentation I have done on the app.
on 07-10-2024 09:13 AM
Thank you. I've asked our Devices Team to look into this and I will post back as soon as I receive an update.
on 07-10-2024 09:01 AM
Hi Michelle. Updated thanks the profile.
on 07-10-2024 08:48 AM
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 07-10-2024 08:45 AM
Hi Michelle. It was definitely there in the past as we enabled it but it's disappeared. It was called gaming and conferencing. It basically put gaming and conferencing at the top of the streaming to lower lag, ping etc.
Even when you Google it, it tells you in the settings where it is, but it isn't anymore. Just wondered why if anyone knew why it was removed.
on 07-10-2024 08:22 AM
The only setting I can see in the app is settings, network settings, then SQM. Is this what you mean?
@KeithFrench - have you come across this before?
