Gaming and conferencing. Missing in settings.
leenineplus
Message 31 of 31
Hi all. The gaming and conferencing setting on the eero app seems to have disappeared. No option to turn it on anymore for my son with his Xbox. It used to be on there. Any advice please.
Lee Kendall
30 REPLIES 30
Message 21 of 31
Hi @leenineplus
I have reconnected & updated my eeros to V7.6.1-62. Optimise for conferencing and gaming is still there, it was formerly called SQM. This can be found by going to:-
Discover > eero Labs > Optimise for conferencing and gaming
How effective this is will be down to how the eero identifies such IP packets. QoS is normally used for this, but without more information from eero, it is impossible for me to guess.
Message 22 of 31
Hello again,
My colleague has checked this and advised that the same features are there, the name has just been changed to SQM.
Message 23 of 31
Thanks Keith, no problem. I also checked the app and I couldn't see it so I'll let you know what the devices team advise.
Message 24 of 31
Hi Keith. I can't remember. Lol. It was a few months ago and in the app it just said Gaming and conferencing. You could switch it on or off.
It used to be there and just disappeared.
Regards Lee
Lee Kendall
Message 25 of 31
Hi @Michelle-TalkTalk
I am busy at the moment testing the Sagemcom new firmware & may not be able to look into this with the eero until later today, or tomorrow.
Hi @leenineplus
Where in the app was this QoS setting & I will first look in my own documentation I have done on the app.
Message 26 of 31
Thank you. I've asked our Devices Team to look into this and I will post back as soon as I receive an update.
Message 27 of 31
Hi Michelle. Updated thanks the profile.
Lee Kendall
Message 28 of 31
  • Name
  • Telephone number or Account number
  • Alternative contact number
leenineplus
Message 29 of 31
Hi Michelle. It was definitely there in the past as we enabled it but it's disappeared. It was called gaming and conferencing. It basically put gaming and conferencing at the top of the streaming to lower lag, ping etc.
Even when you Google it, it tells you in the settings where it is, but it isn't anymore. Just wondered why if anyone knew why it was removed.
Lee Kendall
Message 30 of 31
The only setting I can see in the app is settings, network settings, then SQM. Is this what you mean?
@KeithFrench - have you come across this before?
