Grandstream - calls suddenly cutting off
Gleha
Message 20 of 20
I have had an Eero with Grandstream VOIP for over 12 months and have had minimum disruption.
I have not changed any equipment but today calls will ring out and then cut out after about 10 seconds.
I have turned off Eero and Grandstream 4 times  with no success.
Eero said there was an update due so I did that and turned everything off again twice but to no avail,
I have tried to contact talk talk via my account but just have message saying all agents are busy.
Has anyone else had similar problems and had a solution?
19 REPLIES 19
Message 1 of 20
Hi Gleha
Apologies, our service status page has now been updated to show how to do the reset.
Service Status | TalkTalk Help & Support   Under phone.
Message 2 of 20
2 days without phone has been a nightmare.
Last night expected problem to be resolved.
Looked at status at 8am which said some problems
Checked again at 9.17 to find instructions re Grandstream reset.
Have done that and appears to be OK
some of your customers will have problems locating the reset button - it might be useful to explain where to find it.
Message 3 of 20
Hi @Terry0781
I'm so glad to hear that this is now working 🙂
Ahh thank you. Merry Christmas to you too 🙂
Message 4 of 20
Yes I did Debbie, a few times and the phone light stayed off, the good news is me being a tech expert, 15 mins ago I unlpugged the power from the DVA thingy put it back in and bingo all up and working (who needs grandkids Ha Ha) Big thanks to you and the guy,s working through the night in this weather, Merry Christmas to you all, big thumbs up.
Message 5 of 20
Hi @Terry0781
Did you try this again this morning (after the fix was rolled out in the early hours this morning) holding the pin in until the leds on top start blinking simultaneously?
Message 6 of 20
Hi Debbie
Reason for confusion the chat line reffered to it as ATA, yes reset as you said(actually done this 2 or 3 times over the last couple of days) phone light again flashed for a few seconds and has gone off. Grandstream says I am on line, and I can see all my contacts but when I try to ring nothing, like all the others.
Message 7 of 20
Hi @Terry0781
This the voice adapter - it's the little device that your phone connects to.
Hope this helps 🙂
Message 8 of 20
Sorry Debbie being an old codger with none of my grandkids around, what is the DVA??
Message 9 of 20
Hi @Terry0781
Our Network Engineers have asked if you could try resetting the DVA again please, holding the pin in until the leds on top start blinking simultaneously. Please let me know if there is any change following this.
Message 10 of 20
Hi Debbie
Is this nation wide or area (York), I did a reset on the ATA this morning and now the phone light has gone off, only power light and internet light is on,I tried again a bit later, turned eero off it fired back up again waited 20 min still no phone light on ATA, as we speak, I think I will go out for a coffee (Ha Ha).
Message 11 of 20
Hi Gleha
Our engineers have identified the problem and are actively working to deploy the fix. We expect this to automatically update on your equipment in the early hours of the morning and your normal service to resume. We sincerely apologise and understand the inconvenience this has caused. Thank you for your patience whilst we have worked to resolve this issue.
Please can you retest?
Message 12 of 20
Our Service status page has now been updated
We are aware customers with FTTP services are currently experiencing issues making and receiving calls, our engineers are aware of the issue and are working hard to a resove this. We will provide any updates here, we apologise for any inconvenience this is causing.
Message 13 of 20
Hi Gleha
Apologies for this.
The team are investigating this at the moment as a priority.
Message 14 of 20
No success
Have powered down eero and reset grandstream twice.
No effect
Seems other people are also having problems
Message 15 of 20
Hi again,
Further to my last post -
We’re aware that some Full Fibre Digital Voice (VoIP) customers are currently unable to make and receive  calls.
Latest update: 08:10am 13th December 2023
Service has been restored, we recommend if you're still being affected, to power down both the eero router and the Grandstream digital voice adapter and use the factory reset pin, this will clear the issue.
Message 16 of 20
Hi Gleha,
I'm sorry for the delay. There was an incident yesterday which should now be resolved. Is your voice service currently working?
Gleha
Message 17 of 20
Still waiting for Talk talk to correct fault.
No phone since 9 am this morning.
Seems lots of people having same trouble
Modelman
Chat Champion
Message 18 of 20
I've got the same issue here for incoming and outgoing calls. It's also giving a engaged tone as well sometimes. I wondered why the phone has been quiet this afternoon.
Gleha
Message 19 of 20
Just had update from technical team
Apparently talk talk having problems with VOIP and working to restore service
Told to reboot in 2 to 3 hours
will update if that works
