on 07-12-2024 10:29 AM
I was upgraded to full fibre on Wed.worked great for a few hours. Then pon light flashing and no service since.
3 x on live chat has not got it fixed, what can I do?
on 09-12-2024 02:41 PM
I'll order it now, it should be with you within a couple of working days (usually next day)
on 09-12-2024 02:39 PM
Well fingers crossed this will fix it. When is it coming?
on 09-12-2024 02:13 PM
Yes, it will replace the huawei hub
on 09-12-2024 01:46 PM
Will this replace the black mesh router ?
on 09-12-2024 01:40 PM
No he didn't and yes please
on 09-12-2024 01:26 PM
Hi Steve197,
You should have an eero, did the engineer not leave one? If not then I can arrange to send one
on 09-12-2024 01:15 PM
anybody?????
on 09-12-2024 10:59 AM
Alarm not illuminated, power solid green and the other2 flashing green
on 09-12-2024 10:52 AM
Thanks, Are they all green?
on 09-12-2024 10:35 AM
Power is solid green pon and bottom light are flashing data
on 09-12-2024 10:30 AM
Thanks. Which lights are currently on, on the ONT?
on 09-12-2024 10:13 AM
Huawei
on 09-12-2024 09:43 AM
If you pull out the "pull-up" plastic panel on the top of the router, it will reveal a label on the router itself behind it. It will be one of these three models:-
on 09-12-2024 09:26 AM
on 09-12-2024 09:23 AM
Is black with lots of holes all over it.sorry can't be more precise
on 09-12-2024 08:59 AM
Hi Steve197,
Which router do you have connected?
on 07-12-2024 03:41 PM
Details added to profile. Thanks for your help.
on 07-12-2024 02:39 PM
OK thanks for confirming, it is just the first question that TalkTalk would have asked you anyway. I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
To save yourself time, please make sure that your community profile includes your first & last names, Full Fibre account number & if possible an alternative contact number. This can be done by clicking on your Avatar picture and then clicking on "My Settings" followed by:-
on 07-12-2024 01:48 PM
Numerous times . If I can get it working it goes back offat 6.17 every morning. Then after messing around with it might get it back about 11_ 12 for the whole process to start again the next morning?
on 07-12-2024 01:35 PM
Have you tried turning the ONT off for a full 30 minutes?
