Services all down
Werepaws
Message 21 of 21
Kelly comms have been out to install internet to the flat opposite me
and since which is an hour ago now
my telephone line no longer works and no Gfast signal
I spoke with them about it. But they just left. They have left such a mess with the phone connection points in the communal area and left the phone cabinet open slightly in the street
i am not very happy!!!! As i have no working phone or internet
what the hell were these engineers doing???
20 REPLIES 20
Message 1 of 21
Excellent, thanks for confirming.
Message 2 of 21
Thanks for checking in Debbie. Everything is holding and working fine. Speeds are normal too. So nothing has been affected. Broadband seems stable to my knowledge
Message 3 of 21
Hi @Werepaws
I just wanted to check that everything is still working ok since your last post yesterday?
Message 4 of 21
Hi @Werepaws
Thanks for your reply and I'm so glad to hear that this fault has been resolved.
If you do experience any further issues then please let me know here.
Message 5 of 21
Thanks Debbie!
well. Another engineer came out today. Apparently it was scheduled for a cable pull from the junction box.
however the engineer was able to repair the outside cable damage.
however this didn't restore access to myself.
however the engineer from open reach found that kelly comms had disconnected my pair by cutting it. So he he had to reconect it
now I have voice and data  services restored as do some others from the cable damage outside
thank you for escalating the situation!
Message 6 of 21
Hi @Werepaws
Below is the latest update from Openreach:
Please be advised the last engineer was not able to fix the fault because he found underground cable going into distribution point damaged. Therefore, passing the job back to the Local Network Team (LN) to get the fault resolved. The next update should be available on 04/04/2025.
Message 7 of 21
Hi @Werepaws
Thank you for confirming.
The line test is detecting a fault so I have escalated this straight over to Openreach to be investigated by a line engineer.
I will continue to monitor for further updates and I will post back on this thread.
Thanks again.
Message 8 of 21
Its for my line. The account number. Not the private note phone number
Message 9 of 21
Hi @Werepaws
I'm really sorry about this.
I will run some tests now. Just to confirm, is this for your line? (account number in your Community Profile) or for the line mentioned in the Private Notes section of your Community Profile?
Werepaws
Message 10 of 21
There is no dial tone on the home phone either. Nothing its dead to my property.
Gfast modem picture
Werepaws
Message 11 of 21
 no!! No!!!
there is no telephone signal to my master socket
the DSL modem cor gfast can not sync
there is no internet connection
however if the kelly communications network people hijacked my communications port and gave it to my neighbour opposite that might throw certain messages like the line test above
Werepaws
Message 12 of 21
I still can't respond to direct messages
but the questions Amahle-TT   asking are irrelevant
I don't see how these questions are relevant
the line has been damaged caused by two previous engineers doing work for a neighbour
the broadband is down the modem can not find a signal from the incoming line
It can not sync a signal the line is dead
nothing todo with wifi or anything internal
i know you have todo your checks
it needs an open reach engineer to fix whatever problem has been caused Which is likely inside the cabinet or the external wiring
Werepaws
Message 13 of 21
Need the message limit counter resetting again
the Answer to the question
"Not at the moment because there is no Internet connection available so I won't be able to access the internet if it connects to the Wifi
as im having to use my mobile provider data network 5G"
Message 14 of 21
Being messaged directly. But ran iut of messages to respond back with?
the answer to the amahle-TT
is no I can't use my talk talk connection at home
Message 15 of 21
Its a separate modem. Sagcom fast 4370
its solid orange/amber colour nothing changes if you power cycle it
Message 16 of 21
OK thanks, what colour is the light on the router?
Message 17 of 21
Thanks!
service is still not working. They did something in the cabinet which caused it to stop working im guessing
Message 18 of 21
Hi Werepaws
You can report any damage to Openreach equipment directly to them here - Report damage, vandalism or a health & safety issue | Openreach
Is your service still not working?
Message 19 of 21
Thanks!
just to back up post. Here are some images ive taken
Message 20 of 21
