on 06-04-2025 02:07 PM
Have 5 months left what would my final bill be likely to be?
on 07-04-2025 07:54 AM
Hi Doiter68,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 06-04-2025 10:28 PM
If you make sure that your personal details including TalkTalk phone number or account number are complete on your community profile (click here) then the support team can check your connection for you.
on 06-04-2025 09:17 PM
Wired connection cat8 Ethernet cable 8pm nightly no speed test at that time as if it is being throttled? Sorry for first response with lack of information
on 06-04-2025 08:56 PM
Depending on the root cause of the problem, moving to a new ISP may not necessarily fix it.
If you give a few more details, people may be able to offer help and advice.
For example, you say it is "buffering", so do you think it is a speed issue? have you done speed tests? does it only happen at/around specific times? Are wired connections affected or just WiFi? etc.
on 06-04-2025 08:06 PM
Keeps buffering on Netflix and itvx at 8 at night done soft reset and such like so think my options are limited
on 06-04-2025 03:33 PM
Hi @Doiter68 https://community.talktalk.co.uk/t5/Articles/Cancel-your-TalkTalk-service/ta-p/2204737
Gives the likely costs.
Is their anything we can do to try and improve whatever is making you think of leaving?
