Internet connection loss, intermittent but now becoming more constant
ANC_567
Message 23 of 23
Over the last couple of months we have had regular dropouts (ethernet and wifi before you ask). It became so bad that my wife can no longer rely on her home office (ethernet). In the last couple of days we have suffered dropouts of up to 3 hours.
On Thursday and Friday mornings I had long chat interactions with tech dept. all of which made me start with router resetting, checking internal connections, direct ethernet, in other words nothing seemingly relevant to the symptoms. I should add that TT replaced the router start of October for this and now the problems have returned and worsened.
The chat calls were time consuming and frustrating in that they were frequently interrupted and resumed with a different operator, sometimes starting the same questions. I have lodged a complaint (for which I have a reference number, but not been contacted about, and there is also a tech job no. open when I looked at connection test). I have no information about the progress of this.
I know it is not reliable to add 'hearsay', but other local TT users have reported similar issues in our locality
ANC
22 REPLIES 22
Message 1 of 23
Hi Susan,
Please can you create your own topic and we'd be happy to look into this for you.
Message 2 of 23
@Susan291962
If you would like help from the support team here please start your own topic.
Susan291962
Message 3 of 23
I have had all these problems these past few months it's been an absolute nightmare.  All the same questions all the same hours spent on chat when on my day off. I don't have that amount of hours to spare testing this that and the other. I even changed my package as advised.  Extra extended router added to bedroom,  didn't help. I'm at my wit's end.
Message 4 of 23
I'm glad to hear this 🙂
Message 5 of 23
Yes, have talked to a support representative and its been a massive step forward. Thank you so much.
ANC
Message 6 of 23
Hello again,
Can I just confirm, have the team been in contact?
Message 7 of 23
Thanks again Michelle. It would be great just to talk through the details with someone.
ANC
Message 8 of 23
If you're not available when they call then they will be able to re-schedule a callback for you.
Message 9 of 23
Hi, many thanks. If it helps i wont have time to try any diagnostics today, but i would be free til late morning tomorrow? Also, would it help if you had the current job no.?
ANC
Message 10 of 23
I've passed this straight over now and I'll post back as soon as I receive an update.
Message 11 of 23
That would be great if they'll talk to me directly...but i have to tell ui have been in constant contact over website 'tech (?)' chat and finally a less than inspiring 'case manager', who has eventually booked an engineer who cant come til next Wednesday. If you can (and are allowed) to help solve it i would be just as relieved
ANC
Message 12 of 23
Hello again,
Thanks for checking and confirming. I can raise this over to our Fault Escalation Team for the team to contact you directly. Would this be ok?
Message 13 of 23
Hello Michelle,
Thanks for having a look. Ive had three different ethernet cables plugged between the ONT and the router WAN input, each time checking carefully the connections, and leaving them in situ for some time. Its bizarre, for example last two nights the connection reestablished itself about 2130-2200 hrs and was still in when I went to bed. In the mornings its back to constantly dropping out and trying to reconnect.
ANC
Message 14 of 23
I'm sorry to hear this. I've run a test on the line which has advised - Service is working - problem with ONT connection to router. Check cable is in place and connected to router WAN port. Are all the cables connected securely?
Message 15 of 23
Hi Chris,
To a certain extent. Briefly(?!), we started having intermittent dropouts during September (hadnt been an issue previous to that, full fibre been working since installation some months previously). As we mentioned recent power surges in our area, TT surmised it might be the problem, and sent an identical replacement router. No major issues until about two weeks ago, when dropouts again became too regular for my wife's home office.  Contacted TT chat last thursday and they made me try some in house diagnostics. After that, the broadband connection got worse and in the last few days has been unusable, going off for hours or whole days(down all day today and most of yesterday).
ANC
Message 16 of 23
Did you have the same exactly the same issue with the old router?
Message 17 of 23
You could say so. This is the replacement router they sent a month or so back.
ANC
Message 18 of 23
OK thanks, have you tested with a second router?
Message 19 of 23
I've just had a look (as it dropped out a couple of times this morning already). When it drops out the router fasts flashes orange, while the ONT green LAN flickers or goes off intermittently. Then after a bit, the router goes to steady slow flashing orange for a while and the green  LAN is off. Eventually the router flashes orange/white briefly, green LAN flickers on. Then it all drops out again and repeats
ANC
Message 20 of 23
  • Yes. When we changed to full fibre they fitted a white BT openreach ONT.  (It doesnt quite look like the white one shown in the router set up guide but they didnt comment on this when i was asked for a photo of it from tech chat advisors.) The POWER light and PON light are green. I notice the LAN light flickers lightly when it is working. When it drops out and tries to reconnect, the LAN cycles through flashing and then after a while goes off. This is in sequence with the router going through fast orange flashing/slow orange/brief white/fast orange.....etc
ANC
