My internets down
Antoine33
Message 6 of 6
Constant flashing red light on router turned off multiple times been like this for two days no internet connection
Atirant
5 REPLIES 5
Message 1 of 6
Hi Antoine33,
Openreach have now cleared and closed the fault, is everything OK at your end?
Message 2 of 6
Hi @Antoine33
This fault is still with Openreach, there are no additional updates at the moment.
We will continue to monitor for further updates.
Message 3 of 6
Hi @Antoine33
Thank you.
The line test has detected a potential line fault so I have escalated this straight over to Openreach to be investigated by a line engineer.
I will check on this later this afternoon for additional updates from Openreach.
Message 4 of 6
Amended profile
Atirant
Message 5 of 6
Hi @Antoine33
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
