on 22-11-2024 03:55 PM
Hi, I have received an eero 6 with instructions on how to get the app. What I don't have is the Grandstream component to be able use my phone. Will that be sent to me soon please?
on 09-12-2024 02:36 PM
That's great news, thanks for letting me know 🙂
on 09-12-2024 02:31 PM
Things seem to be ok now, thanks. Having the second eero upstairs works well and I have speeds of 148 down and 143 up. I also find it useful to have the new app so I can tell which device is connecting to which eero. Thanks for your help.
on 09-12-2024 08:03 AM
Hi silvergirl,
Thanks for the update. Are you able to try the eeros in slightly different location to see if you can improve coverage
on 06-12-2024 07:57 PM
Both eero devices are connected, plus the Grandstream for the VOIP. I will reserve judgement for a while because I am having the old problem of my PC upstairs not reaching the speeds it should. I know I get good connections on devices downstairs where the first eero is installed but upstairs I had better speed previously with the Hub2 and FAST 266. Some adjustments needed somewhere, I feel.
on 06-12-2024 07:04 AM
Hi silvergirl
Glad to hear that you've received the eero
on 05-12-2024 08:02 PM
OK, do keep us posted.
on 05-12-2024 07:37 PM
It only arrived late this afternoon so I haven't had time to do anything with it yet. I will let you know when I get that far.
on 05-12-2024 07:28 PM
Cool. And has the wifi coverage improved?
on 05-12-2024 07:25 PM
Hi. I have received the eero, thank you very much.
on 03-12-2024 12:38 PM
Hi silvergirl,
I've ordered the eero, it should be with you within a couple of days
on 03-12-2024 12:31 PM
Yes it will be free of charge
on 03-12-2024 11:23 AM
Hi Chris, Please would you confirm that this second eero will be free of charge?
Thank you for your help, Silvergirl
on 03-12-2024 09:53 AM
Yes, please, and hopefully that will solve the problem.
on 03-12-2024 09:29 AM
Hi silvergirl,
I can send another eero, would you like me to arrange this?
on 02-12-2024 02:34 PM
Thank you Keith, I appreciate your input.
on 02-12-2024 12:57 PM
Hi @silvergirl
Yes, I think I remember your WiFi problems upstairs. Didn't you originally use an old TalkTalk WiFi extender kit, but that caused problems as the inbuilt PLAs had to cross two ring mains circuits & often needed rebooting? Then you had the FAST 266 WiFi booster, which I think helped quite a bit.
I am therefore not surprised that you are having problems with just the one eero 6, most people require a second to form a mesh unit. Mind you, as the eero has no WiFi settings available in the app, I have found that their location is everything. This may be an area that needs further investigation, if not much better using two eero 6s.
Let me have a word with TalkTalk.
on 02-12-2024 12:20 PM
Hi. Over the weekend I installed and set up the eero and Grandstream and all looks fine - until I use my desktop computer. The signal strength is very poor indeed. I have had a lot of help through this forum in the past and I am hoping you can help me again now. Previously, when using the Hub2, I had to have the FAST266 upstairs to boost the signal. What can I do to get better signal from my eero 6, please?
on 28-11-2024 11:13 AM
Hi @silvergirl
Great, I hope all goes well with eero installation. If I can help at all, just let me know.
on 28-11-2024 11:01 AM
Thank you, Keith. I had heard this and my Full Fibre was installed by City Fibre, which is why I wanted my profile checked before I try installing anything.
on 28-11-2024 09:58 AM
Hi @ferguson
The profile only applies to CityFibre customers, if not set correctly the eero will never sync up.
