New eero 6
silvergirl
Super Duper Contributor
Message 30 of 30
Hi, I have received an eero 6 with instructions on how to get the app. What I don't have is the Grandstream component to be able use my phone. Will that be sent to me soon please?
Silvergirl
29 REPLIES 29
Message 1 of 30
That's great news, thanks for letting me know 🙂
silvergirl
Message 2 of 30
Things seem to be ok now, thanks. Having the second eero upstairs works well and I have speeds of 148 down and 143 up. I also find it useful to have the new app so I can tell which device is connecting to which eero. Thanks for your help.
Silvergirl
Message 3 of 30
Hi silvergirl,
Thanks for the update. Are you able to try the eeros in slightly different location to see if you can improve coverage
silvergirl
Message 4 of 30
Both eero devices are connected, plus the Grandstream for the VOIP. I will reserve judgement for a while because I am having the old problem of my PC upstairs not reaching the speeds it should. I know I get good connections on devices downstairs where the first eero is installed but upstairs I had better speed previously with the Hub2 and FAST 266. Some adjustments needed somewhere, I feel.
Silvergirl
Message 5 of 30
Hi silvergirl
Glad to hear that you've received the eero
Message 6 of 30
OK, do keep us posted.
silvergirl
Message 7 of 30
It only arrived late this afternoon so I haven't had time to do anything with it yet. I will let you know when I get that far.
Silvergirl
Message 8 of 30
Cool. And has the wifi coverage improved?
silvergirl
Message 9 of 30
Hi. I have received the eero, thank you very much.
Silvergirl
Message 10 of 30
Hi silvergirl,
I've ordered the eero, it should be with you within a couple of days
Message 11 of 30
Yes it will be free of charge
silvergirl
Message 12 of 30
Hi Chris, Please would you confirm that this second eero will be free of charge?
Thank you for your help, Silvergirl
Silvergirl
silvergirl
Message 13 of 30
Yes, please, and hopefully that will solve the problem.
Silvergirl
Message 14 of 30
Hi silvergirl,
I can send another eero, would you like me to arrange this?
silvergirl
Message 15 of 30
Thank you Keith, I appreciate your input.
Silvergirl
Message 16 of 30
Hi @silvergirl
Yes, I think I remember your WiFi problems upstairs. Didn't you originally use an old TalkTalk WiFi extender kit, but that caused problems as the inbuilt PLAs had to cross two ring mains circuits & often needed rebooting? Then you had the FAST 266 WiFi booster, which I think helped quite a bit.
I am therefore not surprised that you are having problems with just the one eero 6, most people require a second to form a mesh unit. Mind you, as the eero has no WiFi settings available in the app, I have found that their location is everything. This may be an area that needs further investigation, if not much better using two eero 6s.
Let me have a word with TalkTalk.
silvergirl
Message 17 of 30
Hi. Over the weekend I installed and set up the eero and Grandstream and all looks fine - until I use my desktop computer. The signal strength is very poor indeed. I have had a lot of help through this forum in the past and I am hoping you can help me again now. Previously, when using the Hub2, I had to have the FAST266 upstairs to boost the signal. What can I do to get better signal from my eero 6, please?
Silvergirl
Message 18 of 30
Hi @silvergirl
Great, I hope all goes well with eero installation. If I can help at all, just let me know.
silvergirl
Message 19 of 30
Thank you, Keith. I had heard this and my Full Fibre was installed by City Fibre, which is why I wanted my profile checked before I try installing anything.
Silvergirl
Message 20 of 30
Hi @ferguson
The profile only applies to CityFibre customers, if not set correctly the eero will never sync up.
